L-jet minimum fi parts required |
jesiv |
Mar 13 2013, 07:19 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
What are the L-jet fi parts required? I was just thinking less is more...
Thoughts Regards James |
MrKona |
Mar 13 2013, 07:31 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
I think they're all required. Seriously, I doubt the factory included any extra parts. (IMG:style_emoticons/default/biggrin.gif)
What are the L-jet fi parts required? I was just thinking less is more... Thoughts Regards James |
Mike Bellis |
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
All of them...
jesiv |
Mar 13 2013, 07:35 PM
Mike Bellis |
Mar 13 2013, 07:42 PM
timothy_nd28 |
Mar 13 2013, 09:26 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
If you're not in a cold climate enviornment, you can lose the cold start valve. The anti backfire/ decel valve seems optional, mines off and runs fine. Your aux air valve isn't needed to start the car, many of them are seized and not working on others. The key items would be the brain, dual relay, resistor pack, CHT, airflow meter and a good rubber boot.
Black22 |
Mar 13 2013, 09:28 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) You beat me to it Tim.
timothy_nd28 |
Mar 13 2013, 10:45 PM
Also the thermo time switch isn't all important, if you live in a warm climate
Drums66 |
Mar 14 2013, 12:13 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
If you're not in a cold climate enviornment, you can lose the cold start valve. The anti backfire/ decel valve seems optional, mines off and runs fine. Your aux air valve isn't needed to start the car, many of them are seized and not working on others. The key items would be the brain, dual relay, resistor pack, CHT, airflow meter and a good rubber boot. .....And of course, no negative air leaks (IMG:style_emoticons/default/idea.gif) (major cause for grief) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)(vacuum) |
jesiv |
Mar 14 2013, 10:36 PM
If you're not in a cold climate enviornment, you can lose the cold start valve. The anti backfire/ decel valve seems optional, mines off and runs fine. Your aux air valve isn't needed to start the car, many of them are seized and not working on others. The key items would be the brain, dual relay, resistor pack, CHT, airflow meter and a good rubber boot. .....And of course, no negative air leaks (IMG:style_emoticons/default/idea.gif) (major cause for grief) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)(vacuum) Thank you!! This is what I was looking for |
Lo-Fi Version | Time is now: 8th June 2024 - 07:26 AM |
