WTB: engine cooling flaps, thermostat, etc, the whole thing |
r3dplanet |
Mar 14 2013, 08:03 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
My most recent unpleasant discovery is that my car completely lacks the cooling flap system. No thermostat or anything. Probably some cool bro took it out to save a few ounces before I bought the car.
Does any one have a complete get-up to sell me? And by complete I mean complete because I have no idea how it really even installs and I don't want to find that I'm missing something small but important. The engine is a 1973 1.7 liter if it makes any difference. Thanks! -marcus |
euro911 |
Mar 14 2013, 10:23 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Marcus, I've got a couple sets of flaps, but no thermostat or cable (don't need the thermostat here in So Cal).
I have a stock set and a freshly blasted set. I can post pix tomorrow ... |
lonewolfe |
Mar 15 2013, 03:13 AM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Marcus, I've got a couple sets of flaps, but no thermostat or cable (don't need the thermostat here in So Cal). I have a stock set and a freshly blasted set. I can post pix tomorrow ... Hey Mark! I need a complete set as well less the thermostat. Let me know if you have an extra set. |
r3dplanet |
Mar 15 2013, 10:32 AM
PM sent
etoddy |
Mar 15 2013, 09:25 PM
Newbie Group: Members Posts: 1 Joined: 28-December 12 From: SoCal Member No.: 15,298 Region Association: None |
Check out TheSamba.com for a thermostat- there appear to be several for sale.
There's also a shop out there (I can't recall the name, maybe another can fill in the blank here) that rebuilds them, but it ain't cheap. After discovering my 912E's thermostat had ruptured, I searched in vain for a replacement, so I chose the latter route. I could tell a HUGE difference between running with and without one. |
etoddy |
Mar 15 2013, 09:41 PM
Here's that shop I used. . .
http://www.awesomepowdercoat.com/thermosta...ed_rebuilt.html There's an exploded view at the bottom of the page outlining what parts you need to restore your cooling system. |
euro911 |
Mar 16 2013, 04:48 AM
Marcus, here's what I found at the shop on Friday. The passenger side flap is not rusted, it's coated with a rust preventive spray I applied after blasting (last year). I never got around to coating the rest of the assembly. You just need to wipe down and paint the color of your choice (preferably, semi-gloss black).
These are the plastic bushings that the connecting shaft rides in - in the fan housing, and the linkage from the connecting shaft to the passenger side flap. If you're planning on installing a complete system (including a thermostat), there should be a pulley mounted to the driver side of the case just a little forward of and below cylinder #2 that the cable from the thermostat runs through. The pulley is part # 021 119 769 A (# 48 in the diagram below) The pulley bolt is part # 271 821 767 (# 47 in the diagram below) ... and a couple of spring plates (retainers for the connecting shaft), # 41 in the diagram below. You can easily make the retainers yourself if OEM ones are hard to find. Awesome Powdercoat manufactures new (correct temp range '85~90' degree) thermostats for $120. click here ... You'll also need the thermostat mount (# 55 in the diagram above) if you don't already have one Awesome Powder coat has the cable too, but they want $10 for it. I think you can get stranded cable at Lowes or Home Depot for less (IMG:style_emoticons/default/confused24.gif) |
euro911 |
Mar 16 2013, 04:59 AM
Hey Mark! I need a complete set as well less the thermostat. Let me know if you have an extra set. Still looking, Mark. Other than the blasted set in the post above, I only found a spare passenger side flap so far. I'll be at the shop again later today, I'll look some more. |
r3dplanet |
Mar 16 2013, 01:30 PM
Awesome 'possum.
I don't have any of it. Beyond the flaps, I don't have the pulley, bolts, hold-downs, nothing. Good to see that the thermostat is for sale somewhere, albeit expensive for what it is. Thanks! |
Lo-Fi Version | Time is now: 4th June 2024 - 01:06 PM |
