jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
The topic line says it all.
Cap'n Krusty |
Yes. And the smog requirements go with either the engine or the chassis, whichever is newer .....................
The Cap'n |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
crazy question.......who's gonna check on what motor's in the car if we don't tellum?
dfelz |
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California ![]() ![]() |
Your car is also a 76, so even the stock version needs to pass smog in CA, 75 and earlier are excluded from required smog test. So either way, even if was an old school diesel, which i am assuming that wasnt your plan the car would need to be smoged.
But those vw turbo diesels are great, i love them. The 1.8 from the 2000 era golt TDIs are awesome, i have a few friends that have them, one who is a diesel mechanic that outfitted the engine for more ponies (IMG:style_emoticons/default/biggrin.gif) |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
If you transplant the whole diesel with all the computers and what not you can get it exempted.
a914622 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest ![]() |
or if you transplant the 1.6 td or 1.9 td and get it licenced Diesel i think your smog checks go away? There has been guys swapping diesel into there 82-89 vanagons. Once they get a referee ok the title gets a "diesel type" and there smog goes away.
I dont live there just passing on what i have read on the vanagon swaps. jcl |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I think that most diesels don't have to pass emissions. The newest ones may, but I don't believe the older ones do.
Well worth looking up at dmv.ca.gov if you're looking into a swap like that. --DD |
TurboWalt |
Member ![]() ![]() Group: Members Posts: 157 Joined: 14-March 10 From: Chattanooga, TN Member No.: 11,463 Region Association: Northern California ![]() |
Vehicles that qualify for an exemption from smog check:
"Diesel powered 1997 year model and older or with a Gross Vehicle Weight rating (GVWR) of more than 14,000 lbs" In order to make that work for you would most likely require an appointment with the smog "refree". They would verify that you indeed have a diesel. The kicker is whether or not the ref just say's "yep it's a diesel" and sends you on your way. Or if they decide to needle you and check that every single emission related component required for your donor engine is there. They know that the diesel will be exempt from further inspection so I don't know how tough they are on the diesel swaps. On the petrol swaps they need to do a good job so future smog checks can be performed at a regular vs referee station. One solid rule regarding engine swaps in CA, your donor engine must be from the same model year or newer than your chassis. Once your good with the referee, DMV will change the fuel on your title (no more smog checks). |
Lo-Fi Version | Time is now: 16th July 2025 - 04:32 PM |
