Engine Run In, For a re build |
newdeal2 |
Nov 20 2004, 08:57 AM
Unregistered |
Has anyone thought of this...Just mount the engine/Tranny without connecting the shafts and shifter assembly to test run the engine and if so what was the proceedure?
DNHunt |
Nov 20 2004, 09:09 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
You doing this in the car or on a stand? I started mine on a stand so I could check for leaks and I left the clutch disk out so there wouldn't be any chance that I would have the output shafts turning. (Safety, kids around). If in the car start it in neutral so you don't have to drop it again and add the clutch.
Dave |
newdeal2 |
Nov 20 2004, 10:05 AM
Unregistered |
I will have the tail end up to install the engine/tranny and thought I could leave the shafts and shift shaft off until I check everything [after 20 mins or so at 2000 rpm]. This way I save a few steps if I need to pull it back out.
Any thoughts/suggestions? |
DJsRepS |
Nov 22 2004, 04:00 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
Dont see a problem starting it in any gear with the axles out. 2 smooth round disks turning whatever direction one would have to try to hurt themselves on that. It cant hurt the gearbox. Note about oil leak SirAndy of this board found a nice one on mine. If you remove the Tstat pully from the block put short screw and washer back as that hole goes deep into the block and oil.
Lo-Fi Version | Time is now: 4th June 2024 - 09:12 AM |
