adiokyro |
Oakland, Ca ![]() ![]() Group: Members Posts: 74 Joined: 27-January 13 From: United States Member No.: 15,437 Region Association: Northern California ![]() |
stipped down a 77 911 front suspension and got it blasted and powdercoated. ordrered these sweet 16x6 fuchs from alex magro, just got em and they look sweet!!!
got 2 questions: 1.What kind of rear spring set up should i use? what weight springs? I am running stock 77 911 front suspension with new konis , poly graphite bushes, 16x6 fuchs. should i get the coil over kit? what weight springs to match stock torsion bars? 2. this front suspension came with the under body sway bar but my 73 2.0 has stock 914 sway bars front and rear, what should i use? thanks!!! ![]() ![]() |
stuttgart46 |
Member ![]() ![]() Group: Members Posts: 305 Joined: 17-December 07 From: Santa Monica, CA Member No.: 8,474 Region Association: None ![]() |
What engine are you running?
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
Here's my .02cents, if it were me I would use the 911 front suspension.
- 19mm T bar - 20 mm Sway bar ......only down side is this set up lacks adjustability. For a daily driver and some DE. This set up is great as I've been down this path. If you do want to utilize the old setup, you will have to weld up new sway bar tabs. As for rear springs...Bilsteins with -200+lbs worked great. At least it worked for me. Enjoy the journey:) |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
with the stock front swaybar and 19mm torsion bars, I would go with 150lb springs (if you are doing threaded perches on the rear)
Lo-Fi Version | Time is now: 16th June 2024 - 05:34 PM |
