> Fuel pump
914itis
post Apr 5 2013, 08:40 PM
Car run great! With a a little rattling / rubing sound .it has been that way for over a year, with a litle time in my hands, I decide to trouble shoot. I check everywhere thinking that I may have dropped a bolt, somewhere , none. Check the belt, tight . While checking the heat exhangers, I noticed it was coming by the fuel pump, yes it is the fuel pump.
I had a spare pump, I decided to replace it, the noise on the second pump was almost unbearable.
Oh well! Just wanted to share.
Replies(1 - 9)
Madswede
post Apr 6 2013, 12:45 AM
Flat Out Driver
When my car had the carbed bus motor in it, the low-P fuel pump made lots of noise for a couple days before it died. Tapped it with a hammer a couple times, and it worked and quieted down. My only conclusion from that was that it needed attention. (IMG:style_emoticons/default/confused24.gif)
post Apr 6 2013, 06:23 AM
914-6 GT in waiting
Paul - I have a 2 port if you need it. $n/c. I can bring to hershey or ship if you need it now. Mark
rhodyguy
post Apr 6 2013, 06:36 AM
carbs or fi?
k
914itis
post Apr 6 2013, 06:58 AM
Gentkemen,
I don't think there is anything Wong other then, thy are just noisy.
It is fuel injection and the 2 port pumps.
Scott, the car belong to the previous owner of the body shop. The new owner pushes it out as he needed the space. I have his number and have been tryng to contact him with no answer. His voice mail is full. I was also told that the engine was a 2270. I will keep you posted .
rhodyguy
post Apr 6 2013, 07:31 AM
2270 with stock d or ljet? either way your pump shouldn't make a bunch of noise.
rhodyguy
post Apr 6 2013, 07:32 AM
914itis
post Apr 6 2013, 07:44 AM
It is a 2.0 djet, the first pump is not that noisy, just a small noticeable rattle . The replacement was loud. The are both Bosch with different part numbers.
post Apr 6 2013, 08:57 AM
Paul, from your description I take it that it is still mounted under the battery. Is is still mounted on the factory vibration isolators?
914itis
post Apr 6 2013, 09:33 AM
QUOTE(76-914 @ Apr 6 2013, 10:57 AM) *
Yes, it is at the factory location, mounted with a bracket, not sure what the isolators look like. Any pics?
- Lo-Fi Version Time is now: 27th November 2026 - 07:13 PM
