Gas tanks, All years the same? |
TheCabinetmaker |
Nov 21 2004, 12:39 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
With the exception of the filler cap and expansion tank, are there diffs in the tanks themselves thru the years?
Will they interchange? Thanks. |
type47fan |
Nov 21 2004, 02:43 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
A quick search shows two (2) part numbers issued:
1970 - 1973 914 201 010 10 1974 - 1976 914 201 010 12 The strainer screens in the bottom of the tank are different in '75-'76. Don't know what the differences in the tanks are, but I would suspect they are interchangable from a fit and function aspect. Wayne (type47fan) |
TheCabinetmaker |
Nov 21 2004, 04:43 PM
The tank on my 75 had some loose rust particles accumulated around the screen, and any sudden turn would cause the car to stall. Very bad in a 914, right? I examined some extra tanks I have, and found one from a 73 that was in excellent condition inside. The 73 and 74 appear to be identical in every respect. The 75 does not have the mounts for the charcoal canister, the mounts for the expansion tank are different, and the strainer screen is about a third the size of the pre 75. Expansion tank on the 75 is plastic. Looks like the tanks themselves are identcal. I changed tanks, and filter, and all is well now. I can slide all the way around a corner (roads are wet today (IMG:style_emoticons/default/biggrin.gif) )and no more stall (IMG:style_emoticons/default/smilie_pokal.gif)
pre 75 expansion tank, charcoal canister, and filler weigh 6lbs 8oz. The 75 weighs 2lbs 14 oz BTW, I started with one gallon of gas in a dry tank, drove two blocks to the gas station and the reserve light went off at 2.3 gals. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:54 PM |
