| PanelBilly |
Apr 6 2013, 04:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,953 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
This is one of the jobs I never finished. I installed new rubber squeegies in the doors and when I operate the windows, they pull out. Tried a little glue, but it doesn't hold. Any ideas
Here's how I did it. First, Mark sent me a new set of them and they look more pronounced if I can use that term. I worked the metal some more. It was a bit bent up. Then I slid the rubber in with the help of a little soap. Lastly, I use a set of pliers that had been modified for pulling plug wires. They were perfect because then crimped the edge of the metal without touching the rubber. |
| Cupomeat |
Apr 6 2013, 05:44 PM
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,349 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
GREAT! (IMG:style_emoticons/default/agree.gif)
I have never been able to finish off my doors for this reason as well. I'd LOVE to know. Thanks for bringing this up. |
| messix |
Apr 6 2013, 05:55 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
does the channel that the rubber fit in to need to be peened down like the a-pillar part out the front targa seal?
| r_towle |
Apr 6 2013, 06:03 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Mine were preened over on each end
| Mike Bellis |
Apr 6 2013, 10:54 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I got new ones from 914 rubber. Mine pull out in the middle every time I lean my arm on them. I eventually just removed them. To save weight... (IMG:style_emoticons/default/poke.gif) Well, to save me from going crazy.
Weird... I think the new soft rubber may be too soft to stay in the extruded aluminum thingy. Perhaps you could remove the aluminum and peen in several places to keep it in. |
| zonedoubt |
Apr 6 2013, 11:50 PM
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Put some talcum powder on them.
| rhodyguy |
Apr 7 2013, 06:54 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
clean the windows with a diluted vinegar/ammonia solution and wipe them with newspaper. like REALLY CLEAN. dress the the seals with a light coat of glycerin.
| balljoint |
Apr 7 2013, 07:37 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
Should he wash his arm and put glycerin on his shirt sleeve too? (IMG:style_emoticons/default/biggrin.gif)
Sounds like they don't fit. Maybe there were a couple made too thin to engage the channel properly? How many people have actually installed them? Start by checking the group buy thread. If it's been bought ahead for a final assembly in 5 years they won't be able to help you but someone can answer the question. |
| 76-914 |
Apr 7 2013, 08:10 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Well, I feel strange. I've done them on both my 914's w/o incident?? I can tell you this. The strip was a very tight fit and required some coaxing. I did not use any lube to help it slide nor did I relieve any crimps in the channel. PITA but they work great after a few years.
| balljoint |
Apr 7 2013, 09:19 AM
Well, I feel strange. I've done them on both my 914's w/o incident?? I can tell you this. The strip was a very tight fit and required some coaxing. I did not use any lube to help it slide nor did I relieve any crimps in the channel. PITA but they work great after a few years. After a few years? Where did you get them from? |
| Daiberl |
Apr 7 2013, 09:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
I have the same problem with my rubber seal, really annoying, I haven't tried to glue them in yet. Are yours the one from 914rubber?
| 76-914 |
Apr 7 2013, 09:37 AM
Well, I feel strange. I've done them on both my 914's w/o incident?? I can tell you this. The strip was a very tight fit and required some coaxing. I did not use any lube to help it slide nor did I relieve any crimps in the channel. PITA but they work great after a few years. After a few years? Where did you get them from? Let me look it up. I keep my receipts. Maybe PP or Mikey?? I gotta tell ya. (IMG:style_emoticons/default/poke.gif) When I saw that you had replied I quickly reread my last post thinking OMG, what has he turned this into? But upon reading your reply I became concerned that you had taken ill in that you usually take a certain, shall we say license, with that much material. (IMG:style_emoticons/default/lol-2.gif) Or, did you get put in timeout again? (IMG:style_emoticons/default/happy11.gif) |
| Mikey914 |
Apr 7 2013, 09:51 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,778 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Let me know if you are having issues. I'd be happy to send you a replacement. Justy PM me your email and I can resend another set. The durometer of rubber was the same as sample OEM part. Maybe just a a out of tollerence part. Doesn't happen very often, but possible.
Either way I'll take care of it. -Mark |
| Mikey914 |
Don't glue them, it would be a mess.
Thx |
| Daiberl |
Apr 7 2013, 09:56 AM
Don't glue them, it would be a mess. Thx Ok, I will try to squezze the aluminum a bit. My problem is that every time I close the door the end of the rubber comes out of the channel. Looks like a winter project since I have to get the door apart to get to the channel, or is there an easier way? |
| rhodyguy |
Apr 7 2013, 10:13 AM
i guess he could wash his hands but why would he need to? you might think your windows are clean. a little windex and paper towel isn't going to do the job. the sharp edge will drag on accumulated grime that may fold the edge under and out it pops due friction. the glass should be slick. or don't try really cleaning, run a fat bead of silicon in the channel and call it a day.
k |
| 76-914 |
Apr 7 2013, 10:19 AM
Don't glue them, it would be a mess. Thx Ok, I will try to squezze the aluminum a bit. My problem is that every time I close the door the end of the rubber comes out of the channel. Looks like a winter project since I have to get the door apart to get to the channel, or is there an easier way? Did you remove the channel to replace the strip or try to stuff it in place? |
| Daiberl |
Apr 7 2013, 10:35 AM
Don't glue them, it would be a mess. Thx Ok, I will try to squezze the aluminum a bit. My problem is that every time I close the door the end of the rubber comes out of the channel. Looks like a winter project since I have to get the door apart to get to the channel, or is there an easier way? Did you remove the channel to replace the strip or try to stuff it in place? First I had the channel removed, then I put the door back together and now when it comes off I simply stuff it back on. |
| PanelBilly |
Apr 7 2013, 02:22 PM
| rhodyguy |
Apr 7 2013, 03:15 PM
when you guys installed these did you remove the end caps? did you slide them in? was it a tight fit almost to the point of stretching? if they slid right in with not much, if any effort, there's a prob with the squeegee. as i recall, with the ones i bought from the bird it took some time to work them in. glycerin in the channel and on the bead that slides in. walked down the channel a little at a time and fell back to relieve the stretch. i waited 24 hrs to trim to the correct length. glad i did. they had recovered and sucked back on the triangle window end.
Lo-Fi Version | Time is now: 16th April 2026 - 12:36 PM |
