| teamgravy |
Apr 8 2013, 02:52 PM
Newbie ![]() Group: Members Posts: 17 Joined: 9-November 12 From: Austin Member No.: 15,128 Region Association: Southwest Region |
I am building a 914 track car and we are trying to wire back up the wipers and I can't find the relay. I didn't see a relay in teardown and don't see anything like the one mentioned in the left-over parts bins.
I just wanted to wire the motor direct so I can toggle the wipers on and off with a switch (sans relay) but I can't find any diagrams that don't involve the relay and my attempts to "hot wire" it have failed. Any ideas, can't I run switched 12v+ to it and ground the necessary wires to test and/or run it this way. I understand the wipers would not return to the down position automatically but just need them for occasional mist/rain at the track. Any help you can offer is much appreciated, 3 weeks till first race. -Daryl |
| Dave_Darling |
Apr 8 2013, 03:10 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The relay should be on top of the fuse panel. The fuse panel drops down by removing a couple of screws.
Using a relay is generally the best idea; it not only allows for control of the wipers the "normal" way but it also takes some of the electrical load off of the wiper switch. (I think...) --DD |
| teamgravy |
Apr 18 2013, 03:34 PM
The relay should be on top of the fuse panel. The fuse panel drops down by removing a couple of screws. Using a relay is generally the best idea; it not only allows for control of the wipers the "normal" way but it also takes some of the electrical load off of the wiper switch. (I think...) --DD I have searched for this relay and can't find it with the parts. Not sure i ever got one with it as half the electronics were missing when I got the car. I just wanted to have something if they get rain while we are on the track. |
| Mike Bellis |
Apr 18 2013, 07:21 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
There is no wiper relay unless you have an intermittent setup. Wiper switch controls the wiper motor.
You should be able to jumper to one of the leads via a switch to make it work. If you want it to park itself then it's a little more work. |
Lo-Fi Version | Time is now: 16th April 2026 - 01:11 AM |
