> Wiring Harness
stuttgart46
post Apr 9 2013, 06:45 AM
I'm in the middle of a conversion to a 6 and I was curious to see if you guys that have done this retain your wiring harness or do you fabricate a new one.
Does anybody make one for purchase or are they typcially custom built?
TIA
Chad
Replies(1 - 4)
bdstone914
post Apr 9 2013, 07:50 AM
bdstone914
Perry on this board makes Very nice engine harnesses for 6's.
http://www.914world.com/bbs2/index.php?sho...amp;mode=linear
Cap'n Krusty
post Apr 9 2013, 09:42 AM
Cap'n Krusty
I REALLY don't like "ditto" posts, but I am making an exception. Like Jeff Bowlsby's FI and engine harnesses for the 4 cylinder cars, Perry's /6 harnesses are a thing of beauty, things you can't just knock out yourself, done better than you ever could.
The Cap'n
stuttgart46
post Apr 9 2013, 11:48 AM
Thanks for the heads up guys.
SLITS
post Apr 9 2013, 01:53 PM
"This Utah shit is HARSH!"
1st conversion: I used the /4 engine harness and matched function (not color) of the wires. I tied the /4 into the /6 engine harness and taped off the unused wires of the /6 harness. I also used the /4 relay board.
2nd conversion: Pulled the 911 connector plate and tied in the /4 main body wires again matching function.
3rd conversion: Used the /4 main harness and wired direct to the /6 engine harness.
4th conversion: Will use the 914 14 pin main connector with a mating 14 pin connector from the 911 engine harness.
That said, I am a CASOB and Perry's harnesses are nice!!!!!
- Lo-Fi Version Time is now: 31st July 2025 - 10:49 AM
