partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
The dude at Pelican can't seem to tell me what the amperage is for this relay.
Is there any way to tell? The relay you are looking for is part number 141 951 253 B and is forsale for $6.75 I was thinking of putting one in with more amperage in place of the stock one since the addition of the H4's 100W, I believe. |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
100W @ 12v =8.3 Amps. Most relays are rated for 20 Amps minimum. You should be OK. Use 2 if you are worried.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
A Google image search showed this:
http://www.amazon.com/RELAY-MULTIPURPOSE-1...T/dp/B00B2WQ6N0 It says 40A on it. 200W / 14V = 14A, which is well under 40. So it's fine. --DD |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
our electrical group is top notch. (IMG:style_emoticons/default/thumb3d.gif) we have some walking dictionary's here.
partwerks |
If it makes any more difference, I am using those pilot lights as well.
Where do I stick the second relay? |
partwerks |
Isn't the relay for the lights a round or, or is it rectangular?
Cap'n Krusty |
Different. The relays at the lights are for the motors. The lights themselves don't have relays. This relay will be for the lights, which put too much load on the switch. Common VW problem.
The Cap'n |
partwerks |
So I never really had a relay for it under the dash??
Lo-Fi Version | Time is now: 4th July 2025 - 10:55 AM |
