How to get it off!, Rusty screw...need help here |
howardchen327 |
Nov 22 2004, 03:07 AM
Newbie Group: Members Posts: 24 Joined: 24-October 04 From: Victoria, B.C. Canada Member No.: 3,005 |
Here is the story:
I decided to took the rocker panel off to check if there is any rust devil on the longs. I had the rocker panel on the driver side off. Good news are that they look pretty good! (will post pics if I've chance (IMG:style_emoticons/default/biggrin.gif) ) When I try to took off the one on passenger's side, I broke them. They wrere rusty & well fasten.....I broke the notchs...Damn now I can't get them off (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/pissoff.gif) (IMG:style_emoticons/default/headbang.gif) Any suggestiongs? (IMG:style_emoticons/default/pray.gif) PS. Where can find those plastic nails (or pins?) that bolt the rocker panel? Thanks (IMG:style_emoticons/default/Yack.gif) (IMG:style_emoticons/default/wacko.gif) |
Series9 |
Nov 22 2004, 03:12 AM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
First, use a (IMG:style_emoticons/default/sawzall-smiley.gif) or something similar.
Then drill and tap. Problem solved. |
howardchen327 |
Nov 22 2004, 03:51 AM
How about (IMG:style_emoticons/default/sawzall-smiley.gif) another notch?
sj914 |
Nov 22 2004, 04:14 AM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
QUOTE(howardchen327 @ Nov 22 2004, 01:51 AM) How about (IMG:style_emoticons/default/sawzall-smiley.gif) another notch? (IMG:style_emoticons/default/agree.gif) You could use a cut off wheel and make another notch and maybe squirt some liquid wrench on it before you try to turn it. |
J P Stein |
Nov 22 2004, 04:23 AM
Nasty little bastards.
Often you can get on em' with a pair of vise grips. Often when you do you'll snap the buggers off. As the man said, drill & tap. Use new stainless hex head bolts & anti seize. |
seanery |
Nov 22 2004, 08:29 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I've had decent luck getting the rusty screws out with an impact screw driver. Sears has them.
Aaron Cox |
Nov 22 2004, 09:37 AM
vice grips on the shank of the screw....BTDT
type47 |
Nov 22 2004, 10:08 AM
dremel...
i'd suggest using regular pop rivets when reinstalling the rocker panel. the price of plastic ones is about $25 for 6! which i think is too high for me and not being a CW, i put in metal ones that cost about $.10/each, about 1/100th the price of the plastic ones.... |
tod914 |
Nov 22 2004, 11:28 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
QUOTE $25 for 6 I only paid a couple of dollars for mine and they were from a Porsche dealer. The black plastic pop rivets are NLA. They have clear plastic ones now. Contact your local Porsche dealer and get a price. They are not that expensive. Regarding the screws, Auto Atalanta has a nice rocker kit. It has all the screw, fasteners, etc. Don't remember the price. Was a little pricey for what it is, but it is complete and correct. If you get it from them, tell them how you want it shipped. |
Lo-Fi Version | Time is now: 4th June 2024 - 08:49 AM |
