| 914itis |
Apr 11 2013, 10:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
What are the pros and cons using a 2 ports instead of 3 ports pump? Is it a matter of preference?
| AZ914 |
Apr 11 2013, 10:27 PM
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,469 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I think the 3 port was an early pump and the 2 port was the late pump... not sure if there is a carb vs. FI difference..
| Dave_Darling |
Apr 11 2013, 11:06 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Easier plumbing if you use the 3-port pump in a car that originally had a 3-port pump. Likewise, using the 2-port in a car that came with one is easier.
No real functional difference that I am aware of, once you deal with the inlet and outlet sizes. --DD |
| JamesM |
Apr 13 2013, 09:37 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,182 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
What are the pros and cons using a 2 ports instead of 3 ports pump? Is it a matter of preference? Availibility and saving a couple hundred bucks. Then u can use that couple hundred to buy SS lines and relocate to the front trunk. Unless you are trying to stay completly original go with the late pump. |
| old dog |
Apr 13 2013, 09:53 AM
Member ![]() ![]() Group: Members Posts: 63 Joined: 14-December 12 From: Oxnard,CA. Member No.: 15,257 Region Association: Central California |
What are the pros and cons using a 2 ports instead of 3 ports pump? Is it a matter of preference? Availibility and saving a couple hundred bucks. Then u can use that couple hundred to buy SS lines and relocate to the front trunk. Unless you are trying to stay completly original go with the late pump. I agree completely, this is a very common thing with the older Alfa Romeos. The two fitting pump is less expensive, still Bosch quality and will be easier to find and replace in the future. |
Lo-Fi Version | Time is now: 4th March 2026 - 05:05 PM |
