| speed metal army |
Apr 16 2013, 09:45 PM
Waiting for the rain to stop... ![]() ![]() ![]() Group: Members Posts: 1,073 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Having some grief finding a source for some heavy rear springs.
Thanks in advance! (IMG:style_emoticons/default/chowtime.gif) |
| 914pipe |
Apr 16 2013, 10:05 PM
Say......TEEEEEEEN!!!!! ![]() ![]() Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
In a stock form, not sure if http://www.paragon-products.com/ got them. For coilover configuration you can try paragon, colemanracing.com or even ebay
| speed metal army |
Apr 16 2013, 10:30 PM
In a stock form, not sure if http://www.paragon-products.com/ got them. For coilover configuration you can try paragon, colemanracing.com or even ebay No dice at paragon that I could find.Not looking for coilovers..Or maybe I should be?? (IMG:style_emoticons/default/idea.gif) |
| r_towle |
Apr 17 2013, 12:49 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
In a stock form, not sure if http://www.paragon-products.com/ got them. For coilover configuration you can try paragon, colemanracing.com or even ebay No dice at paragon that I could find.Not looking for coilovers..Or maybe I should be?? (IMG:style_emoticons/default/idea.gif) The rears are already coil overs... Go to Coleman racing and get the adjustable perches for the smaller diameter springs. Then you can get any spring rate you want, and they are a lot cheaper than the normal diameter. Rich |
| bluhun |
Apr 17 2013, 01:41 AM
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
Having some grief finding a source for some heavy rear springs. Thanks in advance! (IMG:style_emoticons/default/chowtime.gif) Elephant Racing has them. |
| bulitt |
Apr 17 2013, 02:51 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Eibach has a catalog where you can order by diameter and spring rate, but not cheap. Thinking about 120$/ pair.
| Phoenix-MN |
Apr 17 2013, 05:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
| ww914 |
Apr 17 2013, 08:20 AM
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Having some grief finding a source for some heavy rear springs. Thanks in advance! (IMG:style_emoticons/default/chowtime.gif) I have a pair of 220 lb springs you can have for $75 plus shipping. |
| Chris Pincetich |
Apr 17 2013, 01:38 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
If you need greater than 180 lbs for rear springs, best to swap to the parts that allow the 2.5" diameter (non stock) springs which come in lots of lengths and degrees of stiffness. (IMG:style_emoticons/default/beerchug.gif)
It may be the only option. I did this three years ago and appreciate having spring perches w more adjustments for ride height in the back. |
| Andyrew |
Apr 17 2013, 03:23 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
I got some springs from summit racing. But I have true coil over perches from Coleman Racing. I think I paid like $80 for a pair of springs new... Whatever pound you what in 25lb increments. I used 10" springs.
| speed metal army |
Apr 18 2013, 09:43 PM
I got some springs from summit racing. But I have true coil over perches from Coleman Racing. I think I paid like $80 for a pair of springs new... Whatever pound you what in 25lb increments. I used 10" springs. Hey Andrew, Are the shock diameters the same between bils and konis?Also how long is the sleeve on the kit you bought?Thanks Man! |
| Dasnowman |
Apr 18 2013, 10:06 PM
You miss 100% of shots you don't take! ![]() ![]() Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada |
Hi Tom there is a spring place in Surrey by Scott Rd that has springs any shape and size and weight rating. I have them re arc and temper my worn out toyota leaf springs on my truck and also had them lower and stiffen my jetta springs.
Dendoff Springs |
| speed metal army |
Apr 18 2013, 10:09 PM
Hi Tom there is a spring place in Surrey by Scott Rd that has springs any shape and size and weight rating. I have them re arc and temper my worn out toyota leaf springs on my truck and also had them lower and stiffen my jetta springs. Dendoff Springs Hey thanks Snowy!Im digging the adjustable coilover business..If I can make my Konis work,im in for the smaller dia springs and the adjustability. How is the car? |
| Andyrew |
Apr 18 2013, 10:51 PM
I've got koni yellows in the rear.
Shock Diameter I dont believe is the same.. I think I had to have a machine shop machine out the coil perch a few hundreths. This was 10 years ago... but It was like $40 bucks. |
| speed metal army |
Apr 19 2013, 12:07 AM
I've got koni yellows in the rear. Shock Diameter I dont believe is the same.. I think I had to have a machine shop machine out the coil perch a few hundreths. This was 10 years ago... but It was like $40 bucks. Hey Andy, Which threaded sleeve length did you go with? |
Lo-Fi Version | Time is now: 27th July 2026 - 01:49 PM |
