| 76-914 |
Apr 17 2013, 06:57 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I tried to install new brake lines today but apparently I need help. The old lines are S/S and are being replaced w/ rubber Meyle's. The old line has a small end on each end whereas the Meyle has one small and one large. (IMG:style_emoticons/default/WTF.gif) It fit's tightly on the hard line off the caliper but loose as a goose on those 1/2 union fittings which are both a bit smaller.
old n new ![]() different size ends ![]() ![]() I have more pic's if needed. The size difference is appx .020. Attached image(s)
| '73-914kid |
Apr 17 2013, 08:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Just dab a dollop of black RTV on the hose, and let it sit over night. You'll be fine (IMG:style_emoticons/default/smash.gif)
But yeah, remove the union from the car. the hose mounts to the car, and the hardline screws directly into the hard line. |
| Elliot Cannon |
Apr 17 2013, 11:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
If you don't use the union, don't you have two female fittings? One on the hose and one on the car?
| Elliot Cannon |
Apr 17 2013, 11:14 PM
Wait a minute! German auto part, made in Italy, with Russian writing on the label? No wonder it doesn't fit. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif)
| 76-914 |
Apr 18 2013, 08:11 AM
Thx, makes sense. Duh! Technically speaking, this doesn't have to go in the what I did WRONG thread, does it? (IMG:style_emoticons/default/biggrin.gif)
| type47 |
Apr 18 2013, 11:19 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
| Elliot Cannon |
Apr 18 2013, 12:54 PM
...don't you have two female fittings? One on the hose and one on the car? doesn't the hard line have a captured male threaded nut to screw into the female end of the rubber line? ![]() So no double female seeing each other.... I think you're right but what size is it?? |
| bare 1 |
Apr 18 2013, 01:19 PM
Member ![]() ![]() Group: Members Posts: 122 Joined: 27-October 04 From: Apache Junction viaWhidbey Is. Member No.: 3,019 Region Association: None |
Technically there are no unions in the line. Different fitting. Lose that adapter on the car and the lines will go together like Scotty boy says.
| 76-914 |
Apr 18 2013, 04:58 PM
Lo-Fi Version | Time is now: 12th March 2026 - 11:41 PM |
