> Stuck rocker cheesehead screws, The three on the bottom
moldygreg
post Apr 18 2013, 11:26 PM
Stay Golden
First time these rockers have been off ever! Drilled out original rivets and then cleared out three ponds of dirt! Amazingly, rust free!
Anyway, the damn three cheesehead screws won't budge. Snapped one off and will have to drill out (another fun project forthcoming)
Currently blasting and letting them soak 24 hours with penetrating lube from Tacoma screw
http://www.tacomascrew.com/s.nl/it.A/id.61346/.f
Questions: Is there a penetrating bolt busting lube that reigns supreme or is mine good enough?
How long should I wait?
Any other tips? I don't have access to a welder so I can't tack on a better bolt head to loosen unfortunately.
I also have mapp gas, but the rocker panel seems like it's acting like a heat shield and I suspect isn't getting the bolt hot enough. (IMG:style_emoticons/default/smash.gif)
Replies(1 - 5)
euro911
post Apr 18 2013, 11:40 PM
I use PB Blaster and/or Liquid Wrench, but any penetrating lube should work. For tough ones, I also drill and use an easy-out.
rhodyguy
post Apr 19 2013, 03:24 PM
Aero Kroil works well. tacoma screw products or online. that you have to get the product to defy gravity doesn't help much. esp on the top of the threaded hole/tip of the screw so it can drain down.
k
post Apr 19 2013, 05:45 PM
twist 'em off if they won't budge after soaking. then install rivenuts where you need 'em.
moldygreg
post Apr 19 2013, 10:36 PM
Stay Golden
Thanks all! These little guys were stuck!!
Was 2 for 6. I soaked for 36 hours and then used mapp gas and locking vise grips. The dirt that came out was laughable!
They've never been off before. Good tip on rivnuts. I end up drilling the stuck ones out and then tapping new 6mm 1.0 screw.
Dasnowman
post Apr 19 2013, 11:44 PM
You miss 100% of shots you don't take!
Wurth Rust off ICE freezes small bolts and screws works great.
If you have easy access to the head of bolt or screw I just use a zip cut and make a flat head on the top of the screw or bolt and loosen it off.
- Lo-Fi Version Time is now: 31st July 2025 - 09:50 AM
