> suspension torque specs..., website with these listed?
cha914
post Jan 21 2003, 11:50 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus
title pretty much says it all... I am torquing everything back on, and although I usually just torque it till it breaks, I thought I would try and find some real numbers before I go ahead and break stuff.
Thanks,
Tony
Replies(1 - 10)
ChrisReale
post Jan 21 2003, 02:19 PM
Sleazy
The Haynes manual has some numbers listed on the first page of each chapter. Only number I recall off the top of my head is 38 lbs for the rear top shock mounts. If you dont have that book, Ill be happy to relay the info to you, but let me know if you want me to do that, because I am lazy. (IMG:style_emoticons/default/tongue.gif)
cha914
post Jan 21 2003, 02:34 PM
I have the haynes manual...but wasn't able to find many specs...but maybe i wasn't looking in the right places...
Would still appreciate other sources though...
Thanks again,
Tony
J P Stein
post Jan 21 2003, 02:49 PM
Irrelevant old fart
The specs are there in the suspension sections.
Following their nomenclature is a bit of a challenge, tho.
Dave_Darling
post Jan 21 2003, 04:27 PM
914 Idiot
The sad part: The specs in the Haynes manual are all there is!! For everything else, you're supposed to know "M6 fastener into steel is XXX lb-ft, M8 into aluminum is YYY lb-ft"... Either that, or guess. (IMG:style_emoticons/default/rolleyes.gif)
Yipes! (IMG:style_emoticons/default/blink.gif)
--DD
ChrisReale
post Jan 21 2003, 04:40 PM
Sleazy
Guessing can also be dangerous, at least in my case. I had to re-thread the top of one of my new Koni Sports because I torqued it on WAY to hard. All it took was a die job, but still, I was ready to give myself the :gilloutine:
cha914
post Jan 21 2003, 05:46 PM
so what did you end up torquing your koni sports down to?
knowing myself, that is exactly what I will do...I am always stripping threads and breaking bolts...tighter is better right? (IMG:style_emoticons/default/tongue.gif)
anyway, that is what Iam trying to avoid...
Tony
ChrisReale
post Jan 21 2003, 07:32 PM
Sleazy
I made the mistake of not checking my tools before I started using them, (in this case, the torque wrench) and torqued one side down to like 120 lbs!! Should have been between 36 and 43 lbs!!! (IMG:style_emoticons/default/pain30.gif)
Brad Roberts
post Jan 22 2003, 11:22 PM
914 Freak!
Ok. I received the new torsion bars for "the class car" today and noticed they have a handy torque spec "white paper". I will post these here and make sure they make it into the final website design for the club.
Thanks for bringing this up.
B
Mueller
post Jan 22 2003, 11:27 PM
914 Freak!
Chris,
That reminds me of what on of my buddies did to his tranny
he was supposed to tighten to 25 IN LBS and not 25 FT LBS....cracked the case on his '65 Mustang
cha914
post Jan 23 2003, 11:10 PM
bump..
Brad you got that white paper handy? I am finishing up tomorrow... otherwise I will just break shit as usual (IMG:style_emoticons/default/tongue.gif)
Thanks,
Tony
- Lo-Fi Version Time is now: 9th July 2025 - 12:02 PM
