timing change |
timing change |
ruddyboys |
Nov 24 2004, 07:22 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
If you install a different dizzy, or new cam would this effect timing? Could the timing be off the factory specs or will it stay the same.
d7n7master |
Nov 24 2004, 01:52 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
If I understand the question... The moment you loosen the dizzy's collar to remove the dizzy, your timing is no longer set. I always mark the dizzy's position prior to removal. That will help to get you in the ballpark when you re-install but you still need to re-set the timing. (IMG:style_emoticons/default/biggrin.gif)
Red-Beard |
Nov 24 2004, 02:04 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Advance will be _slightly_ different on each dist. I set mine close to spec, then tune by ear. I wish I had a knock sensor and a way to adjust on the fly...without cutting a hole in the firewall.
Root_Werks |
Nov 24 2004, 02:27 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Why are 914-6 folks cutting holes in firewalls to check timing? (IMG:style_emoticons/default/rolleyes.gif)
I believe your question is: Will I change my timing with different compenents? Yes and no. It all depends on how you run your car and the overall set up. I usually set timing by full advance. So say 30 degrees at 6k rpms. Does that mean your static or idle timing will be different? Probably if the dizzy is not stock. But set at a full advance, not at an idle. i also use the "ear" method. Sometimes you can set an engine up nicely, but get it on the road with cheap 87 octane gas and hear it ping. I am cheap so I run 87 in all my cars. Hench the timing is backed off a little. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 09:00 AM |
