assembly and break-in lube question |
jmargush |
May 2 2013, 08:34 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I have been assembling my 2056 with Brad Penn break in oil on all the parts as I go.
When it is complete and I go to fill the crank case with oil do I run all break in oil or is that just used on assembly? Is the synthetic snake oil from Raby/gibbs the preferable way to go now? If so does the prelube from assembly with Brad Penn hurt anything? |
Matt Romanowski |
May 2 2013, 10:52 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I have been assembling my 2056 with Brad Penn break in oil on all the parts as I go. When it is complete and I go to fill the crank case with oil do I run all break in oil or is that just used on assembly? Is the synthetic snake oil from Raby/gibbs the preferable way to go now? If so does the prelube from assembly with Brad Penn hurt anything? You usually use assembly lube when assembling becuase it stays on/in things better than oil, but not too big a deal. Use the break in oil for when you fire it up and probably the first 500 miles (or whatever they suggest) then switch to your fill of choice. |
yeahmag |
May 2 2013, 02:19 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
From my experience Brad Penn Break-In oil turns to practically water after you break in the cam. I'd dump it immediately after the 20 minute break in and run Brad Penn 20w-50 Racing Oil after that.
TheCabinetmaker |
May 2 2013, 03:32 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm with Aaron. 20 minutes and the break in oil is gone.
I use oil on the rings and pistons only. Clevite red assy lube on everything else. |
Java2570 |
May 2 2013, 03:50 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Thank you guys, that's good info as I'm about the fire up my rebuild and I'm using Brad Penn break in
oil..... |
Lo-Fi Version | Time is now: 7th June 2024 - 11:21 AM |
