1973 914 1.7L Relay Board Schematic, No Power from the Relay Board to the Fuel Pump |
Roadsterman60 |
May 2 2013, 01:06 PM
Newbie Group: Members Posts: 11 Joined: 17-December 12 From: Tehachapi CA 93561 Member No.: 15,261 Region Association: Central California |
Help! Help! Has anybody out there got a clear schematic of a 1973 1.7L relay board that you can share (the one in the Chilton shop manual is washed out and blurry)?
I need one to try and figure out why I am not getting power out of the relay board to the fuel pump. I have 12 volts to the power supply relay (new) and pins # 30 and # 85 on the fuel pump relay (new). I also have continuity from pin # 87 on the fuel pump relay to the fuel pump, so the problem seems to be something that's not happening in the pin # 86 circuit of the fuel pump relay, and, due to the terrible schematic I have, I can't locate the problem. Any help/suggestions would be greatly appreciated. |
Bob L. |
May 2 2013, 01:33 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Dave_Darling |
May 2 2013, 03:33 PM
Sounds like the ECU isn't grounding pin 86 of the fuel pump relay. Double check that the ECU is getting power and that it is plugged into the four-pin connector on the relay board correctly.
--DD |
Lo-Fi Version | Time is now: 1st June 2024 - 11:41 AM |
