test fuel pump |
test fuel pump |
last337 |
May 4 2013, 03:08 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
So I'm thinking my problem may be my fuel pump. Is there a way to test it?
ellisor3 |
May 4 2013, 03:24 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
If you have power to it, you should hear it run when the switch is turned over. If it is out of the car, run power from the battery and see if you hear it.
last337 |
May 4 2013, 03:42 PM
I Hear it running but I'm not sure if its supplying fuel at correct pressure when car starts running rough
Mike Bellis |
May 4 2013, 03:45 PM
Bucket, hoses, gauge, regulator, gas, power...
Hook it all together on a bench. |
ellisor3 |
May 4 2013, 03:59 PM
(IMG:style_emoticons/default/agree.gif) also, when you get it off, try spraying brake cleaner into the pump, you may have debris from the gas tank that is clogging it up.
Lo-Fi Version | Time is now: 6th June 2024 - 02:52 AM |
