last337
May 4 2013, 03:08 PM
So I'm thinking my problem may be my fuel pump. Is there a way to test it?
ellisor3
May 4 2013, 03:24 PM
If you have power to it, you should hear it run when the switch is turned over. If it is out of the car, run power from the battery and see if you hear it.
last337
May 4 2013, 03:42 PM
I Hear it running but I'm not sure if its supplying fuel at correct pressure when car starts running rough
Mike Bellis
May 4 2013, 03:45 PM
Bucket, hoses, gauge, regulator, gas, power...
Hook it all together on a bench.
ellisor3
May 4 2013, 03:59 PM
also, when you get it off, try spraying brake cleaner into the pump, you may have debris from the gas tank that is clogging it up.
