Engine running super rich |
mepstein |
May 5 2013, 05:54 AM
914-6 GT in waiting Group: Members Posts: 19,321 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Car is a stock '71 w/ d-jet. All fuel lines and vacuum lines replaced. I was having engine issues with it running very poor. I got the engine running but now it it runs super rich. How can I lean it out. The knob on the ecu only does so much.
TheCabinetmaker |
May 5 2013, 06:52 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
How do you know its running rich? You have an afr Meter hooked up? How rich is it? Have you checked vacuum on the mps?
mepstein |
May 5 2013, 07:29 AM
JStroud |
May 5 2013, 07:34 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Check fuel pressure?
Jeff |
mepstein |
May 5 2013, 07:38 AM
TheCabinetmaker |
May 5 2013, 07:39 AM
Leaky or stuck injector.
mepstein |
May 5 2013, 07:42 AM
Bleyseng |
May 5 2013, 07:45 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
first test the CHT sensor cuz if that goes bad the mix goes super rich.
JStroud |
May 5 2013, 07:50 AM
TheCabinetmaker |
May 5 2013, 07:51 AM
mepstein |
May 5 2013, 08:31 AM
mepstein |
May 5 2013, 08:32 AM
Doesn't mean anything the pressure regulator controls the pressure, mine was running rich, checked fuel pressure was 31, changed it to 28, runs better. Jeff ok |
913B |
May 5 2013, 09:58 AM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Leaking cold start injector.
76-914 |
May 5 2013, 10:11 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,512 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I look at Curt's first question re: "how do you know that it is running rich"and your reply is that you can smell it. Either your part Cheetah or we're talking about a rich idle condition. Which is it?
Kaduku |
May 5 2013, 10:41 AM
Member Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
I am having the same problem, I think. Starts very easily, smells strongly of gas upon starting that stinks. After about a minute or two of idling, the idling drops dramatically then goes up and down, to where it almost stalls.
Runs like crap for a mile or two then settles to a somewhat normal idle. Then after it really warms up it settles to a high 1200-1400 RPM. I am having HPH in Redwood City fix her up soon right after I rebuild my pedal assembly. |
mepstein |
May 5 2013, 11:32 AM
I look at Curt's first question re: "how do you know that it is running rich"and your reply is that you can smell it. Either your part Cheetah or we're talking about a rich idle condition. Which is it? If I stand around the car while its running for a couple minutes, the car, the garage and my clothes all reek of gas. |
mepstein |
May 5 2013, 11:33 AM
I am having the same problem, I think. Starts very easily, smells strongly of gas upon starting that stinks. After about a minute or two of idling, the idling drops dramatically then goes up and down, to where it almost stalls. Runs like crap for a mile or two then settles to a somewhat normal idle. Then after it really warms up it settles to a high 1200-1400 RPM. I am having HPH in Redwood City fix her up soon right after I rebuild my pedal assembly. Not exactly what I'm getting but similar. The high idle is also there. |
Rand |
May 5 2013, 12:26 PM
Check the MPS. If the hose isn't connected properly, or the MPS won't hold vacuum, it goes full rich.
mepstein |
May 5 2013, 02:08 PM
76-914 |
May 5 2013, 02:33 PM
I think there are at least two things here. You might get better performance to warm up if you install the washer beneath the cut sensor. Brad Mayer? Here sells them. Does the idle hunt even after full warm up when you say the idle is still high. Because both the hunting and high idle are classic signs of a vacuum leak. Block everything on the vacuum system except the MPS and see how it runs.
Lo-Fi Version | Time is now: 13th June 2024 - 10:12 PM |
