Car won't start, crap! |
raw1298 |
May 7 2013, 08:22 AM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
I have been starting my car and driving in and out of the garage for about two years with no problems. Now I turn the key and nothing. Could the starter just quit like that? I have a battery tender on it so there is plenty of juice. Any ideas?
7TPorsh |
May 7 2013, 08:46 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
fuses?
xperu |
May 7 2013, 09:01 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I have been starting my car and driving in and out of the garage for about two years with no problems. Now I turn the key and nothing. Could the starter just quit like that? I have a battery tender on it so there is plenty of juice. Any ideas? Check all your grounding points and clean them. Mike |
raw1298 |
May 7 2013, 09:05 AM
I'll check that again. The solenoid clicks one time, and itislike the starter won't turn.
ericoneal |
May 7 2013, 09:18 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
i had this exact problem last month. Have a look at this thread, maybe it will help...
starting issues Turns out there was a relay on there that was fried. Since I bypassed that, my car has been starting better than ever. Do the screwdriver trick to see if your started is still good. |
raw1298 |
May 7 2013, 09:29 AM
I have one of those relays on mine. I will check that out. Thanks for the info.
rgolia |
May 7 2013, 11:34 AM
GeoJoe Group: Members Posts: 705 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
How about the seat belt bypass wire under the passenger seat.
SirAndy |
May 7 2013, 11:38 AM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have one of those relays on mine. I will check that out. Since those relays are usually added as a band-aid for a failing starter, even if it turns out to be the relay, you might want to look into getting a new or refurbished starter. (IMG:style_emoticons/default/shades.gif) |
7TPorsh |
May 7 2013, 11:39 AM
does the car bump start and run?
raw1298 |
May 7 2013, 03:45 PM
I have one of those relays on mine. I will check that out. Since those relays are usually added as a band-aid for a failing starter, even if it turns out to be the relay, you might want to look into getting a new or refurbished starter. (IMG:style_emoticons/default/shades.gif) I will most likely replace the starter before I put it on the road, so I might as well do it now. Any recomendations on where to get one? |
TheCabinetmaker |
May 8 2013, 08:47 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Anywhere but your flaps. Mexican rebuilt crap!!!!!!!!!!!!!!!!!!
I take all my starters and alternators to a local independent rebuilder. Search for one in your area. |
Jon H. |
May 8 2013, 01:48 PM
Member Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
Give your battery terminals a little twist by hand and see it starts. If does then clean your terminals.
Jon |
TheCabinetmaker |
May 8 2013, 04:12 PM
raw1298 |
May 8 2013, 09:32 PM
Terminals are very clean. I am assuming it is a combination of relay and bad starter. The gear connects with flywheel but starter motor won't turn. Will have to wait until Saturday to check further.
raw1298 |
May 8 2013, 09:36 PM
Thanks for all the help!!
raw1298 |
May 19 2013, 01:41 PM
Found time today to get under the car and check it out. I had a bad connector on the solenoid. Crimped on a new one and it fired on first try like before. Now to finish this project!!
Rand |
May 19 2013, 02:14 PM
Found time today to get under the car and check it out. I had a bad connector on the solenoid. Crimped on a new one and it fired on first try like before. Now to finish this project!! Yay, another vote for doing the right thing instead of promoting the stupd starter relay band aid. |
raw1298 |
May 19 2013, 02:18 PM
I will still replace the starter before putting it on the road. The one that is on it I got at a swap meet.
Lo-Fi Version | Time is now: 9th June 2024 - 08:37 AM |
