What's this noise?, I think it broke my car |
newto914s |
Nov 25 2004, 10:13 AM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
I posted last night thinking I had a dropped valve seal. I recorded the sound I was hearing, the intermitant scrap/drag sound, and about 5 seconds after I shut off the recorder their was a pop and the engine stalled. Now it won't start(it cranks really slow)
Help!!! I can't up load itthe file, so e-mail me if you want to hear it. I'll send it to you. newto914s@yahoo.com |
Joe Bob |
Nov 25 2004, 12:42 PM
Pull valve covers and look for loose rockers THEN....do a compression check....you may have dropped a vlave seat. Continual cranking with a dropped seat will chinger up the cylnder if the seat or top of the piston is hitting the valve....
a loose rocker will indicate the seat failure....zero compression....IF the rockers are all tight...can show a "slight" valve problem...either way it's tear down time if the rocker is loose and no compression... |
newto914s |
Nov 25 2004, 12:44 PM
here goes. I uploaded it to some free web hosting site, and saved the file as a jpg. It is a wav file though. Your media player should be able to figure that out. If not change the extention back. Good luck
http://sam2.3h.com/images/engine_noise_3wav.jpg Thanks a ton Curt. He listened to it and thinks it's a seized piston. I tried and can't turn the engine by hand(one wheel jacked up, car in gear, rotating the wheel) |
Aaron Cox |
Nov 25 2004, 12:47 PM
sounds VERY BAD!!! (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/ohmy.gif)
newto914s |
Nov 25 2004, 12:52 PM
How'd you get it to work aaron. I it's not working and I just put it up. This is pissing me off, but what should I expect from free.
Just e-mail me. I'll send it right off, till I figure this web hosting out. |
newto914s |
Nov 25 2004, 12:59 PM
Thank god for yahoo. Thankwas so much easier.
http://www.geocities.com/newto914s/enginenoise.wav have a listen, oh and happy turkey day to all. |
Aaron Cox |
Nov 25 2004, 01:24 PM
i clicked the link...saved it to my com. then played it with media player..... and then the Noise made me jump
newto914s |
Nov 25 2004, 04:41 PM
I think I'm going to pull the engine out. I'm pritty sure it's officialy junk.
Any got a spare 2 liter laying around, I think I'm in the market? |
xsboost90 |
Nov 25 2004, 10:19 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
hit me up, very local..i have one for sale runs very strong....ill even make you a deal on it.. (IMG:style_emoticons/default/wink.gif)
newto914s |
Nov 26 2004, 12:46 PM
IT WASN'T THE ENGINE!!!! (IMG:style_emoticons/default/lol2.gif)
It was the altenator. Somehow it Froze and was binding up the whole operation. We disconnected the belt and the car started right up. Has this ever happened to anyone else. |
TheCabinetmaker |
Nov 26 2004, 03:46 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
(IMG:style_emoticons/default/smilie_pokal.gif) way to go. sometimes the best advice is just to ignore all the "good" advice and keep looking. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 12:20 PM |
