> OT: 57° "inside" the house,heater won't turn on., burrrrrrr.........
Mueller
post Nov 25 2004, 12:13 PM
914 Freak!
being the cheapskates that my wife and I are, we've been putting off turning on the heater and have just dealt with the cold by using lots of blankets.....finally this morning I said that's enough, we need to turn on the heater to get the chill out of the house...darn furnace won't kick on (IMG:style_emoticons/default/headbang.gif)
with all the cr@p I have in my garage, it's going to take an hour just to get the furnace to do some troubleshooting......
am I the only one that won't turn on the heater until they see frost on the mirrors in the bathrooms??? (IMG:style_emoticons/default/smile.gif)
Replies(1 - 19)
Gint
post Nov 25 2004, 12:20 PM
Mike Ginter
Duh. Open the windows...
Trekkor
I do things...
Yep, only you! (IMG:style_emoticons/default/w00t.gif)
JeffBowlsby
post Nov 25 2004, 12:54 PM
Did you accidentally turn off the manual shut-off switch? Every furnace has one...it usually looks like a light switch mounted near the furnace. If not, check the fuses...duh...I know you would do that... (IMG:style_emoticons/default/wink.gif)
dmilzoff
post Nov 25 2004, 12:58 PM
There should also be a manual reset button (small red button) either on the burner itself or on the Control mounted on the flue (or both). Press the button(s) to reset and wait 60 seconds.
Make sure ALL furnace wall switches (usually with red cover plates) are in the on position.
anthony
post Nov 25 2004, 01:10 PM
2270 club
If it's a pilot light problem 9 times out of 10 it's the thermocouple. The thermocouple only costs about $7 at the hardware store and takes 10-15 minutes to install so it's definitely worth trying before calling in a pro for service.
boxstr
post Nov 25 2004, 01:14 PM
Is it gas or electric??
CCLINWARMANDTOASTY
neo914-6
post Nov 25 2004, 01:16 PM
neo life
I can't get my wife to turn OFF the heater... (IMG:style_emoticons/default/ohmy.gif)
Felix
Alison Baker
post Nov 25 2004, 01:25 PM
57 aint cold Mueller
dan10101
post Nov 25 2004, 01:26 PM
TORQUE-o-holic
Mom says "tough, wear a sweatshirt"....
I just sneek over and turn it on....
Andrew
boxstr
post Nov 25 2004, 01:27 PM
Mike go out and sit in your truck, with the heater on... (IMG:style_emoticons/default/biggrin.gif)
CCLINTELLTHEMDAVELENOXSENTYOU
Alison Baker
post Nov 25 2004, 01:28 PM
Mueller, why dont you get busy on your 914 and that will keep you warm ; also it help take your 914 off of JACKSTANDS !
bongo monkey
post Nov 25 2004, 01:34 PM
Dented member
57 degrees isn't cold, especially for November. I would be uncomfortably warm at 57 degrees.
You silly Californians... Reminds me of the time I went to Los Angeles in October last year. It was 60 degrees and my family was walking around in shorts, but everyone else had coats and one guy even apologized for the cold weather. (IMG:style_emoticons/default/huh.gif)
davep
post Nov 25 2004, 02:07 PM
914 Historian
We have had a cool year in Canada. My parents have had their furnace on at least once per month. They are located near the Ontario/Manitoba/Minnisota borders. Started to get snow here in Brantford, ON today. We have been very lucky so far.
BTW, pay your utility bills, that always helps. (IMG:style_emoticons/default/happy11.gif)
Who did you PO this time?
jimtab
post Nov 25 2004, 02:12 PM
FIRST, check your thermostat to see if it is working...just remove it and cross the wires if it fires the heater then your t-stat is bad, if it doesn't then go to the thermocouple as someone said. Good luck, remember the Donnor party, eat the fat ones first...HA HA.
GWN7
post Nov 25 2004, 02:15 PM
King of Road Trips
I wish it was 57 outside right now.... (IMG:style_emoticons/default/biggrin.gif)
My son & I went to Florida a few years ago and rented a convertible. 10 o'clock at night we pull up to a toll booth with the top down and the guy leans out of the booth. He's wearing a parka, wool cap and gloves. Comfort is relative. (IMG:style_emoticons/default/biggrin.gif)
As mentioned, check master shut off switch, then if the pilot is working, replace thermocoupler. Failing that, call the gas repairman.
redshift
post Nov 25 2004, 05:58 PM
Bless the Hell out of you!
Have you checked to make sure the heater hoses haven't blown off, in the engine hole?
sorry..
M
URY914
post Nov 25 2004, 06:23 PM
Furnace? WTF is that?? (IMG:style_emoticons/default/biggrin.gif)
Paul
neo914-6
post Nov 25 2004, 06:27 PM
neo life
sj914
post Nov 25 2004, 09:07 PM
Is it the burner or blower fan that won't kick on?
- Lo-Fi Version Time is now: 11th July 2025 - 01:18 PM
