Erratic tach in sync with generator idiot light, Now what??? |
Rbcm2005 |
May 8 2013, 08:16 PM
Newbie Group: Members Posts: 49 Joined: 14-January 12 From: Nor. Cal. Member No.: 14,003 Region Association: Northern California |
So we took our first extended trip in our 914 today from Redding down to Sonoma to have our GT flares installed at Original Customs. All in all about a four hour trip. All was good for the first ten minutes but then suddenly no tach. Then I noticed that the tach would wave around wildly and at the same time that the generator light would gradually light up and then dim out. Also the turn signal indicator stopped working.
After several minutes the tach would calm down and work again and then at that point the gen light would go out. The signal indicators never did get back to operating properly. Throughout all of this the car itself continued to operate, starting and restarting, cruising down the highway, up and down the hills just fine. Any ideas as to what is up? As always - thanks for all the help. (IMG:style_emoticons/default/beerchug.gif) |
Rbcm2005 |
May 9 2013, 08:06 AM
Bump for a little help...
Also, one other symptom that I forgot. As soon as I tap the brakes the tach drops like a rock to zero and then resumes operating as soon as the brake pedal is released. |
TheCabinetmaker |
May 9 2013, 10:07 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
blown fuse (#4 from the right I think), or bad tach wire connection at the coil. Why don't you just have mark fix it?
Lo-Fi Version | Time is now: 3rd June 2024 - 03:35 AM |
