running lights |
running lights |
RonnieJ |
May 10 2013, 02:24 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
All I'm at a loss. I checked my lights yesterday and have the follow. I have headlights, turnsignals all the way around, brake lights and backup lights and running light front and rear on the passenger side but no running lights front or rear on the drivers side. I installed all new bulbs and fuses and check the fuse legs seperately and all tested good. Anybody got any ideas because I'm beating my head against the wall at this point Thanks.
monkeyboy |
May 10 2013, 04:25 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Someone will need to verify, but I think the light switch has seperate circuits for left and right.
Dave_Darling |
May 10 2013, 09:37 PM
Grounds. Mixed-up bulbs (single-filament bulb where a dual-filament should be, or vice-versa).
Could be other stuff, but those are the first things to come to mind. --DD |
michael7810 |
May 11 2013, 05:46 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
IF running lights are what I call parking lights; try the turn signal blade with the key off. It bypasses the light switch and activates left or right parking lights (depending on which direction you move the blade of course). If they work, then the circuitry should be OK and the problem is the switch.
RonnieJ |
May 11 2013, 06:44 AM
Thanks all, tracked it down to a bad switch. Got to say this is a first switch I have had going bad since I started driving 914's in 1978.
Lo-Fi Version | Time is now: 3rd June 2024 - 04:43 AM |
