> Rubber parts, Where are they found?
newdeal2
post Nov 26 2004, 07:41 AM
Unregistered
Who stocks the rubber "grommets" for the 914. I need the ones for the piping thru the tins, the drains etc.
Replies(1 - 5)
Rhodes71/914
post Nov 26 2004, 07:53 PM
Glacier
I'm bumbing this cause I would like to know as well.
hargray2
post Nov 26 2004, 11:20 PM
fuh-q
Most any hardware store. They are usually in drawers near the specialty fasteners.
SGB
post Nov 27 2004, 12:04 AM
just visiting
I failed at the hardware store but the FLAPS (autozone in this case) had a bunch of different sized really big grommets actually for PVC valves that I managed to mach up pretty close to the holes for battery cable and alternator harness. O still haven't figured out what to do for the Jpipes. They gotta get really hot I think...
914werke
post Nov 27 2004, 01:43 AM
Ive asked this before but never got much (any) of a reply.
Has anyone had any experiance w/the "Complete" rubber kits offered by Tweeks and the like?
These are the ones that cost a bazillion dollars but claim to have "Every" rubber part on the car included.
There are two versions one OE and one repro for 3-4 hun. less.
For someone doing a ground up or a concours restoration it mighyt be worth it but ..every? (IMG:style_emoticons/default/unsure.gif)
maf914
post Nov 27 2004, 07:20 AM
Not a Guru!
QUOTE(newdeal2 @ Nov 26 2004, 05:41 AM)
A lot of the rubber grommets and rubber boots for the T4 engine tin can be bought through VW dealers. I used the 914 Pet parts list to record all of the part numbers and names for these that I could figure out and then went to the local dealer. I lucked out and found a helpfull parts tech who took the time to look up all of the numbers and order them for me.
The T4 was used in many VW's and buses. Unfortunately there are some differences between all of the applications. The parts numbers for the 914 pieces are all VW numbers. I was not able to find the numbers for the grommets in the rear vertical sheet metal panel, but my originals were still usable for those. I was able to replace the grommets and boots in the left, right and front sheet metal pieces, including the heater tube grommets and the oil pressure sensor boot.
- Lo-Fi Version Time is now: 15th July 2025 - 03:33 AM
