Natedog |
Member ![]() ![]() Group: Members Posts: 107 Joined: 20-October 03 From: Fort Collins, CO Member No.: 1,265 ![]() |
Hello -
So I've started my first engine rebuild and I have a question: I have a 73 2.0 litre 914. On the crankshaft bearings, are there supposed to be small dowel pins holding the bearings in place? The Haynes manual shows a diagram with the dowels but they aren't mentioned in the reassembly directions. The dowels ( 4 total ) should be about 5 mm diameter by 8 mm long. Do I need them? What's the correct size? And where can I get some!? Thanks for your help! Cheers Nate Fort Collins CO 73 914 2.0 73 VW T3 Squareback |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
They keep the bearings from spinning. Not sure where to get them. You might try Jake Raby.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Yes you need them... Why/how did you lose them ??
B |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
rimco probably has them (IMG:style_emoticons/default/wink.gif)
MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
I think aircooled.net has them. They're a standard off the shelf part, iirc.
Natedog |
Thanks!
Is this the right part: Part #: ECA0014 on aircooled.net I'll need four total right? I don't know if this link will work, but anyhow.... http://aircooled.net/new-bin/viewproductde...127200440613509 Guess I'll be doing come carpentry instead tomorrow..... (IMG:style_emoticons/default/sad.gif) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Hey Nate, just noticed you live in the Fat Tire capital of the world. (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/drunk.gif)
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
HELL YES! You need them!!
They are actually there to align the bearings correctly in the saddles to match the oiling passages, not really to keep them from spinning- The align bore crush takes care of that.. Not only are they a must, but they also should not be longer than 8.0mm, if they are they will protrude too far into the bearing and will pich up when you torque it down and wipe out a bearing and piss you off the first time you try to fire it up! I have thousands of them if you can't find any.. |
Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
What exactly does it look like when the crank is shuffle-pinned?
What is the advantage of this? -Britain |
Jake Raby |
Shuffle pins go around the case through bolt bores and have an interferance fit that locks the case halves together and keeps the case from "Shuffling"
We only do it for engimnes making more than 200HP. |
Lo-Fi Version | Time is now: 2nd July 2025 - 07:47 PM |
