| Kaduku |
May 24 2013, 05:55 PM
Member ![]() ![]() Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
Wouldn't it cut the noise a bit?
| kid914 |
May 24 2013, 06:24 PM
ALWAYS lead...NEVER follow!!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,543 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
I was thinking the same thing!
| wndsnd |
May 24 2013, 06:37 PM
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
You would have to use the closed cell foam and not the mastic.
Not sure if you would have to use an additional adhesive as well as the black tops will heat up. |
| bandjoey |
May 24 2013, 08:34 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Been meaning to ask on the same thought
What about spraying Radiant Barrier on the inside? |
| Kaduku |
May 24 2013, 09:05 PM
| euro911 |
May 24 2013, 10:53 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Any material that would dampen resonant vibrations would work. The stock style pad works fine at doing that.
| scotty b |
May 25 2013, 06:16 AM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Pointless on the top unless it were steel. The amount of resonance through the fiberglass top, with rubber strips where it rests on the body, is minimal compared to the body of the car. Dynamat the back wall, doors and strips on the raised portion of the floor. Also remember you DO NOT need to cover the whole panel, all you need to do is stop the vibration. Also look at Lizard SKin. Joe Sayre used it on his car and loves it. I've heared good stuff from others about it
http://www.lizardskin.com/ |
| Mike Bellis |
May 25 2013, 09:52 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
If you have an engine pad or dynamat on the firewall, the majority of noise comes through the glass rear window.
Try some dynamat there... (IMG:style_emoticons/default/biggrin.gif) |
| mepstein |
May 25 2013, 11:45 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,750 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I used this stuff - see below. I wasn't expecting miracles but I am happy with the results. Cost was $45 at pep boys and enough to do the trunk and targa top. Some spray adhesive holds it very securely to the top.
| bandjoey |
May 25 2013, 09:47 PM
That looks like original material. In person how close is it to the original material?
| mepstein |
May 26 2013, 06:54 AM
Lo-Fi Version | Time is now: 9th June 2026 - 01:17 AM |
