Kaduku
May 24 2013, 05:55 PM
Wouldn't it cut the noise a bit?
kid914
May 24 2013, 06:24 PM
I was thinking the same thing!
wndsnd
May 24 2013, 06:37 PM
You would have to use the closed cell foam and not the mastic.
Not sure if you would have to use an additional adhesive as well as the black tops will heat up.
bandjoey
May 24 2013, 08:34 PM
Been meaning to ask on the same thought
What about spraying Radiant Barrier on the inside?
Kaduku
May 24 2013, 09:05 PM
QUOTE(wndsnd @ May 24 2013, 05:37 PM)
This sounds like a better option to not add more weight.
euro911
May 24 2013, 10:53 PM
Any material that would dampen resonant vibrations would work. The stock style pad works fine at doing that.
scotty b
May 25 2013, 06:16 AM
Pointless on the top unless it were steel. The amount of resonance through the fiberglass top, with rubber strips where it rests on the body, is minimal compared to the body of the car. Dynamat the back wall, doors and strips on the raised portion of the floor. Also remember you DO NOT need to cover the whole panel, all you need to do is stop the vibration. Also look at Lizard SKin. Joe Sayre used it on his car and loves it. I've heared good stuff from others about it
http://www.lizardskin.com/
Mike Bellis
May 25 2013, 09:52 AM
If you have an engine pad or dynamat on the firewall, the majority of noise comes through the glass rear window.
Try some dynamat there...
May 25 2013, 11:45 AM
I used this stuff - see below. I wasn't expecting miracles but I am happy with the results. Cost was $45 at pep boys and enough to do the trunk and targa top. Some spray adhesive holds it very securely to the top.
bandjoey
May 25 2013, 09:47 PM
That looks like original material. In person how close is it to the original material?
May 26 2013, 06:54 AM
QUOTE(bandjoey @ May 25 2013, 11:47 PM)
Very close.
