Crush washer and Oil Screen Question, Not dumb questions, dumb people! |
JawjaPorsche |
May 30 2013, 06:29 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Okay, I have taken yall advice and I just removed the oil screen from my 1.7.
Crush washer: I removed the old washer and just put the new on in place of it? What is the purpose of the crush washer? Why not a regular washer. Remember, I am new to this. Also there was a small broken rubber washer (see picture) when I removed the cover. Does anyone know what it was for and do I need it. Again, thank you so much your understanding of a novice mechanic. Your answers are appreciated as usual. Terry Attached image(s) |
bulitt |
May 30 2013, 06:52 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
My gaskets were on so long they were not recognizable as gaskets. I had to pry around with a screwdriver until they came off. Car was new to me so I, like you assumed no gaskets.
JawjaPorsche |
May 30 2013, 06:54 AM
My gaskets were on so long they were not recognizable as gaskets. I had to pry around with a screwdriver until they came off. Car was new to me so I, like you assumed no gaskets. You are correct! They were there just had to scrape a little! (IMG:style_emoticons/default/biggrin.gif) |
TheCabinetmaker |
May 30 2013, 06:58 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The crush washer is what seals the bolts. You need 2. One for the drain plug and one for the sump bolt. There is NO rubber washer. Someone put that rubber on there in an attempt to quell an oil leak. Probably cause they did not have the proper crush washer. That was the same person who put the sump back together without the gaskets. Maybe some unqualified oil changer at jiffy lube. One gasket on each side of the screen. DRY! Torque on the sump bolt is only 8 or 9 foot pounds. The split in the washers go towards the bolt head.
Looks like an oil change was was in dire need! Oh yeah, make sure one of the gaskets is not stuck to the case. Edit: I see you found the gaskets. |
JawjaPorsche |
May 30 2013, 07:45 AM
The crush washer is what seals the bolts. You need 2. One for the drain plug and one for the sump bolt. There is NO rubber washer. Someone put that rubber on there in an attempt to quell an oil leak. Probably cause they did not have the proper crush washer. That was the same person who put the sump back together without the gaskets. Maybe some unqualified oil changer at jiffy lube. One gasket on each side of the screen. DRY! Torque on the sump bolt is only 8 or 9 foot pounds. The split in the washers go towards the bolt head. Looks like an oil change was was in dire need! Oh yeah, make sure one of the gaskets is not stuck to the case. Edit: I see you found the gaskets. Yes I found the gaskets. Thank you so much for help and making me more illiterate when working on my 914. Yall are the best! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:46 PM |
