Mine won't look like COTM but... |
eyesright |
May 31 2013, 08:04 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
...but thanks to PMB/Eric and the crew and the latest group buy, its taking shape. I got the front hubs on last weekend and hope to get after the rears this weekend. The wheels are 5 1/2x14 with some skinny 195 75 14 Goodyears. This will be a DD and cool driver to car shows and drive-ins. The engine is a 2.2 from a T. BTW, I used the studs that came with the hubs for a lock nut set that I got from PP, but I have a good set of bolts I'll use for the other four holes on each wheel. Anybody see a problem with that? |
rick 918-S |
May 31 2013, 08:19 PM
Hey nice rack! -Celette Group: Members Posts: 20,474 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Nice! I see that your in Oklahoma. Hope you and yours are safe. (IMG:style_emoticons/default/unsure.gif)
JmuRiz |
Jun 1 2013, 08:56 AM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
If you we're fishing for compliments, it worked...looks darn nice to me!
eyesright |
Jun 2 2013, 09:04 AM
Yesterday I got the rear hubs off and old bearings out. This week I'll put new ones on and start on the brakes.
Attached thumbnail(s) |
eyesright |
Jun 2 2013, 09:20 AM
This is a '70 914-4 that was a -6 conversion project when I got it. It was a really bad white respray over a red respray over original white. Since it was long past original, I decided to make it signal orange. Anyway, I found two types of rear hubs. Do I understand it right that the one hub was for a 4 bolt wheel and the other one has the extra bosses that could have been drilled for 4 or 5 bolt wheels at the factory? Somebody jump in here if that's not the right explaination. If that is right, those extra bosses don't seem to be as heavy as the 4 that were drilled.
These hubs will be in the mail tomarrow to PMB to wind up in someone else's 4 to 5 bolt conversion. This was the perfect solution to what I had in mind for this car. Thanks Eric and crew. (They will be a little cleaner when they go in the box.) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:07 AM |
