Part ID help, Where did this go/come from? |
--axel-- |
Jun 5 2013, 02:36 PM
Newbie Group: Members Posts: 39 Joined: 12-April 04 From: Lenexa, KS Member No.: 1,920 Region Association: None |
While pulling out the carpet in the driver's footwell, I heard a clunk sound and this piece appeared. It is approximately 4 inches long, and the bolts are fixed. The piece fell behind the carpet, but in front of the pedal backstop board. I can't find anywhere that it would appear to fit. Thanks in advance.
SLITS |
Jun 5 2013, 02:41 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
It is the clutch pedal stop and is mounted to the pedal board at the top of the clutch pedal hole in the board.
--axel-- |
Jun 5 2013, 02:45 PM
It is the clutch pedal stop and is mounted to the pedal board at the top of the clutch pedal hole in the board. Thanks. I just noticed that the bolt spacing matched the board hole spacing. Does this go behind the board, or on the pedal side? It appears that the nuts I took off go to the inside and didn't need to be removed to remove the board. Is this correct? |
--axel-- |
Jun 5 2013, 02:50 PM
It is the clutch pedal stop and is mounted to the pedal board at the top of the clutch pedal hole in the board. Thanks. I just noticed that the bolt spacing matched the board hole spacing. Does this go behind the board, or on the pedal side? It appears that the nuts I took off go to the inside and didn't need to be removed to remove the board. Is this correct? I may have answered my own question. It appears I had to remove the nuts in order to get the board past the clutch pedal. I assume that the plate goes to the backside, and the rubber stopper shows through the cutout for the clutch? |
SLITS |
Jun 5 2013, 05:00 PM
It does not require removal of the piece to remove the board.
Lo-Fi Version | Time is now: 11th June 2024 - 06:13 AM |
