| ppccivilian |
Jun 5 2013, 05:17 PM
Newbie ![]() Group: Members Posts: 13 Joined: 19-January 13 From: Raleigh NC Member No.: 15,388 Region Association: None |
I was working on a clucking shifter bushing (firewall) and while I had the console removed I decided to tackle the VDO clock.
I followed the tips on the Pelican Tech sight: http://www.pelicanparts.com/techarticles/m...lock_repair.htm Trickiest part was getting the crimped bezel off. After that I noticed the Power suply filter cap was blown and needed replacing. I replaced both caps ( 47uF 16v radial capacitors) with replacements found at Radio shack for a cost of $3.00 Im going to calibrate the clock before I put it back together... so far 12 hours and time is still correct Attached thumbnail(s) |
| Jon H. |
Jun 5 2013, 08:31 PM
Member ![]() ![]() Group: Members Posts: 242 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
Radio Shack still sells parts down in the US? Up here in Canada it was bought out and it's now more like a mini Future Shop. The furthest they'll get into an electronic device is the battery cover (IMG:style_emoticons/default/laugh.gif)
Jon |
| Shindog1961 |
Jun 5 2013, 11:52 PM
Member ![]() ![]() Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
I was working on a clucking shifter bushing (firewall) and while I had the console removed I decided to tackle the VDO clock. I followed the tips on the Pelican Tech sight: http://www.pelicanparts.com/techarticles/m...lock_repair.htm Trickiest part was getting the crimped bezel off. After that I noticed the Power suply filter cap was blown and needed replacing. I replaced both caps ( 47uF 16v radial cpas with replacements found a Radio shack for a cost of $3.00 Im going to calibrate the clock before I put it back together... Wow. I would love to have the clock working again. I may have to try this. PM me if you have any other advice/ tips for this repair. |
| ppccivilian |
Jun 6 2013, 05:01 AM
1961,
I have fixed more STUFF by replacing Power Supplies filter capacitors than I think I can list... VERY common failure point. Follow the instruction provided by Pelican and take your time working the bezel of the face. the solder repair will be easy -Robert |
Lo-Fi Version | Time is now: 12th March 2026 - 08:50 PM |
