rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
slick package. no more hiem joints, no more almost had it with the droplinks, and no more side leverage from the throttle cable throwing things out of wack when coming off idle. learned a few tricks when installing...
1. easier w/engine out of the car for the first go round. very doable with engine in but i think the learning curve would be steeper. less running back and forth too. 2. don't misplace one of the brackets. you'll waste a day. (IMG:style_emoticons/default/biggrin.gif) WHERE'S THAT F'IN BRACKET!!! oh, its under the paper towel. 3. assemble the unit but don't tighten every thing up, just snug. take your time and see which option works best for your app as certain variables (webers vs dels, your style of intakes, etc) will factor in. button it up. check for the slave pulley to open at the same time and you're golden except for the final dial in. last picture is the best solution for oil blow out with carbs that i have found. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,807 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Your nuts are loose. (IMG:style_emoticons/default/biggrin.gif)
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
Welcome to the cable linkage club Kevin! Chris has worked really hard on this, made made changes apparently since the early versions, and for the money, I still think this is the best linkage out there. Your setup is slick and clean bud, looks great! |
mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
you will love it. i havnt touched my carbs in over a year.
Lo-Fi Version | Time is now: 31st July 2025 - 07:25 AM |
