thelogo. charging your dead optima, cheap fix procedure |
rhodyguy |
Jun 7 2013, 07:43 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank.
76-914 |
Jun 7 2013, 07:47 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Cool. Let us know how it holds up. How old is the battery?
rhodyguy |
Jun 7 2013, 08:02 AM
bought it years ago at costco and it has been sitting disconnected for a for a long time. the one that came with the green car has been sitting for months and still had 12+v. i used that one for the parallel to 'fool' the charger.
k |
nathansnathan |
Jun 7 2013, 08:28 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
Is that the yellow or the red optima, though?
worn |
Jun 7 2013, 09:12 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank. Isn't that the Optima suggested charging recovery mode? I have a 3-year old red top that is sort of funky about charging but won't die. But the battery in the 911 is a 10-year old die hard, so maybe the money isn't the thing. |
championgt1 |
Jun 7 2013, 09:31 AM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
nathansnathan |
Jun 7 2013, 10:57 AM
Awesome, I was gonna say the yellow ones are supposed to be able to go dead, the deep cycle. Some people do use them for starter batteries. Good tip, I have a red and a yellow at the shop running a sink. (IMG:style_emoticons/default/smile.gif) |
rhodyguy |
Jun 10 2013, 07:27 AM
the dual bat charge worked great. even with the cranking yest the multimeter reads 12.3v this am.
rhodyguy |
Oct 31 2013, 12:11 PM
as i'm the weak 'linker' read this.
martinef1963 |
Oct 31 2013, 08:46 PM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
I tried this on a red top with no success. I took the red top to have it charged, but it couldn't hold a charge.
I picked up another red top (34R) on line for 160 bucks, now have it in the car and have the one I couldn't charge on the stand. Any suggestions? Would love to have two good red tops available. Fern |
rhodyguy |
Nov 1 2013, 09:18 AM
did you try this with your new, fully charged bat?
thelogo |
Nov 5 2013, 07:27 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/bootyshake.gif) I went.with the home depo 20 $ maintainer by black And decker but........... The directions specifically state that you Do not use on dry cell home appliance type batteries The dry cell is the part that has me concerned . As ooptima red Is I guess ? A dry cell But supposed smart chargers work so I'm trying it The red top is pretty much a write off for me at this point I'm sick of it Shame really , but this will be a last ditch effort and if it deforms or b Then screw it!!!___ ;;;;;;;;;;;;;;;;;;;;;;;;;;+;+;;;;;;;;;;;;;;;;;;;;;;;;;; A prince and a great man has fallen .... Ty Cobb |
thelogo |
Nov 5 2013, 07:32 PM
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/bootyshake.gif) I went.with the home depo 20 $ maintainer by black And decker but........... The directions specifically state that you Do not use on dry cell home appliance type batteries The dry cell is the part that has me concerned . As ooptima red Is I guess ? A dry cell But supposed smart chargers work so I'm trying it The red top is pretty much a write off for me at this point I'm sick of it Shame really , but this will be a last ditch effort and if it deforms or b Then screw it!!!___ ;;;;;;;;;;;;;;;;;;;;;;;;;;+;+;;;;;;;;;;;;;;;;;;;;;;;;;; A prince and a great man has fallen .... Ty Cobb This charger http://m.homedepot.com/p/BLACK-DECKER-Batt...BM3B/202710992/ This one , |
pcar916 |
Nov 6 2013, 08:08 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Optima is an Absorbed Glass Mat (AGM) battery and is a sealed. wet cell type.
A dry-cell battery has far too much internal resistance to give out the cranking amps needed for starting our engines. That's the advantage wet cells have... almost no internal resistance, and it's why we can hurt ourselves if the electrodes are shorted. Massive and instantaneous current flow. You should only use chargers that are certified for AGM batteries to get the most out of them. Generally that means no higher than 1 amp, at least from Optima docs. |
bernbomb914 |
Nov 6 2013, 07:41 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
Opyima make a bat. charger for their bat.
thelogo |
Nov 7 2013, 04:17 PM
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank. Please advise anyone who know what I'm talkin about Black and decker charger/maintain er seems to be ok Multi meter is reading on the 20 v setting 12.23 And With mainytaner on 13.20 But im hesitant to leave the maintainer in attended So it s on like only a hour a day . Called black and decker customer service to Find out about agm, charging , they did a automated Voice then just hung up + " I'm comin down there " Ty Cobb., "what a ballplayer " |
TravisNeff |
Nov 7 2013, 05:44 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
hmm, I have recharged my red top optima at least a half dozen times in the past 7 years with a trickle charge and has always worked..
Porsche930dude |
Nov 7 2013, 08:48 PM
Member Group: Members Posts: 399 Joined: 25-November 11 From: Vestal NY Member No.: 13,819 Region Association: None |
usually if my charger doesnt work I put jumpers on a running car and charge it up that way. an alternater puts out alot more amps than my 6 amp charger so it kinda shocks it. then put it ack on the charger till its topped up. If that doesnt work I usually give up on it. I do have a bunch of old batterys iv been thinking about buying a desulfator or building one. Not sure if it would work on an optima but worth a try i guess
thelogo |
Nov 7 2013, 10:02 PM
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank. Please advise anyone who know what I'm talkin about Black and decker charger/maintain er seems to be ok Multi meter is reading on the 20 v setting 12.23 And With mainytaner on 13.20 But im hesitant to leave the maintainer in attended So it s on like only a hour a day . Called black and decker customer service to Find out about agm, charging , they did a automated Voice then just hung up + " I'm comin down there " Ty Cobb., "what a ballplayer " And its optima red top , and it appears to be manufactured in 2008 So May be its time is up ??? |
Porsche930dude |
Nov 8 2013, 05:00 PM
I started doing a bit of expearimenting. With the help of U-tube (IMG:style_emoticons/default/smile.gif) I discovered a good trick of using ebsom salt to desulfate batteries. That paired with a capactive battery charger should repair most batteries. I didnt have any ebsom salt around but I thew together a capaitive charger with spare parts its super simple. and it seems to work great. I got a stone dead battey to full charge. I have yet to see if it will hold the charge but usually they take a few cycles to get them going again. Anyhow I thought id share my findings and I encourage you guys to look into it if you are intrested in fixing your batterys
Lo-Fi Version | Time is now: 2nd June 2024 - 01:20 PM |
