FS: 915 Transmission with 916 upgrade installed, Includes Complete Wevo Shift Linkage and PMS Firewall Bushing |
ChrisFoley |
Jun 13 2013, 11:16 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Open diff. Modified clutch arm. Clutch pulley Bracket. Throttle bellcrank arm. Wevo Trans mounts (blue). 914-4 output flanges.
This gearbox was mated to a stock 2.7L in a 914. The Bug@5speed 916 shifter parts were installed at Tangerine Racing in 2010. Wevo shift lever, tunnel rod, custom 2 u-joint shift rod to trans., Patrick Motorsports firewall bearing. Located at our shop in Manchester, CT. $5250 OBO. Shipping not included. Pictures will be added shortly. |
aturboman |
Jun 13 2013, 12:47 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
Sent e-mail for more detail, thanks.
Open diff. Modified clutch arm. Clutch pulley Bracket. Throttle bellcrank arm. Wevo Trans mounts (blue). 914-4 output flanges. This gearbox was mated to a stock 2.7L in a 914. The Bug@5speed 916 shifter parts were installed at Tangerine Racing in 2010. Wevo shift lever, tunnel rod, custom 2 u-joint shift rod to trans., Patrick Motorsports firewall bearing. Located at our shop in Manchester, CT. $5250 OBO. Shipping not included. Pictures will be added shortly. |
ChrisFoley |
Jun 14 2013, 10:53 AM
Pictures:
Right side of trans showing clutch pulley, throttle bellcrank, and Wevo trans mount. Left side of trans and rear shift rod with u-joints. Firewall bearing and tunnel shift rod modified to match. Wevo Shifter. |
aturboman |
Jun 14 2013, 11:09 AM
Hi Chris got your PM and sent you another e-mail.
Thanks Robert Pictures: Right side of trans showing clutch pulley, throttle bellcrank, and Wevo trans mount. Left side of trans and rear shift rod with u-joints. Firewall bearing and tunnel shift rod modified to match. Wevo Shifter. |
sixnotfour |
Jun 17 2013, 12:21 AM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Wow, that's a deal,
I already bought the 916 kit from Martin though (IMG:style_emoticons/default/sad.gif) |
ChrisFoley |
Jun 22 2013, 08:56 PM
Still available.
Steve |
Jun 22 2013, 09:46 PM
914 Guru Group: Members Posts: 5,611 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
That's a killer deal. I have 10k in mine, but its an 86 with limited slip.
Luke M |
Jun 23 2013, 07:13 AM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Hi Chris,
I have a few questions on the 915.. What year is it out of, looks to be aluminum, what's the gearing(stock or ?), You state modified release fork, it looks to me that it was cut and flipped to use a 914 clutch style setup (push style), what clutch would this setup need to be fitted into a 914 using a 83 3.0 6 ? I have a 83 sc disc/plate/bearing . Thanks, Luke |
ChrisFoley |
Jun 23 2013, 08:26 PM
Hi Chris, I have a few questions on the 915.. What year is it out of, looks to be aluminum, what's the gearing(stock or ?), You state modified release fork, it looks to me that it was cut and flipped to use a 914 clutch style setup (push style), what clutch would this setup need to be fitted into a 914 using a 83 3.0 6 ? I have a 83 sc disc/plate/bearing . Thanks, Luke I'm not sure of the year. It is an aluminum case with a speedo sensor cup on the side of the diff housing. Stock gearing afaik. It still uses the stock pull clutch TO bearing. The arm is extended with the end off a 914 clutch fork so it works like stock. |
0396 |
Jun 23 2013, 09:29 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Hi Chris, I have a few questions on the 915.. What year is it out of, looks to be aluminum, what's the gearing(stock or ?), You state modified release fork, it looks to me that it was cut and flipped to use a 914 clutch style setup (push style), what clutch would this setup need to be fitted into a 914 using a 83 3.0 6 ? I have a 83 sc disc/plate/bearing . Thanks, Luke I'm not sure of the year. It is an aluminum case with a speedo sensor cup on the side of the diff housing. Stock gearing afaik. It still uses the stock pull clutch TO bearing. The arm is extended with the end off a 914 clutch fork so it works like stock. Case looks like a 915 from 76-83....one can zero in via the # on the bottom of the case |
Steve |
Jun 24 2013, 01:58 PM
I agree, it looks like a 911SC trans to me. 84-86 would have a notch for the dme sensor. Should be 8:31 ring and pin.
Lo-Fi Version | Time is now: 7th June 2024 - 01:59 AM |
