WTB 2 straight Predini wheels, late, 1973 only |
914ltd |
Jun 17 2013, 09:34 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Prefer 1973 and not machined early wheels because of design difference.
Please spin them to make sure they are absolutely straight. I already have a pile of bent ones. Thanks, Brad |
hot_shoe914 |
Jun 17 2013, 12:34 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Prefer 1973 and not machined early wheels because of design difference. Please spin them to make sure they are absolutely straight. I already have a pile of bent ones. Thanks, Brad Let me know if you don't find anything. I have a set of 4 with tires mounted I was going to put racing tires on. I might let them go but I need to check them first. Shoe |
Mblizzard |
Jun 17 2013, 12:46 PM
Brad I have 5. Not sure if they are 1973. Is there a way to tell the year? Probably stamped on them but thought I would just in case it was not obvious. They are just sitting there so just let me know if you wind up needing them.
cpavlenko |
Jun 17 2013, 01:20 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Mblizzard |
Jun 17 2013, 07:56 PM
Brad I have 5. Not sure if they are 1973. Is there a way to tell the year? Probably stamped on them but thought I would just in case it was not obvious. They are just sitting there so just let me know if you wind up needing them. I think mine are the early ones as they end in 00. |
914Sixer |
Jun 17 2013, 08:22 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Early 00 wheels can be machined easily IF you can find some one to do the work for a reasonable price. I took a Fuchs wheel and let them measure it and then they cut the the inset down.
Mblizzard |
Jun 17 2013, 09:59 PM
Because mine is a late model I guess I will have to look into that.
914ltd |
Jul 10 2013, 08:18 PM
Still looking! I will buy 1 early if it is straight. Thanks, Brad
Mblizzard |
Jul 10 2013, 08:40 PM
Krieger |
Jul 10 2013, 08:48 PM
Advanced Member Group: Members Posts: 4,728 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Hey Brad, I saw some on The Samba the other day. Don't know if they are early or late.
914ltd |
Jul 11 2013, 09:39 AM
A good way to check for straightness is to stack one wheel on the other and check 360 degrees for ANY gaps between the 2 wheels then stack so the other 2 surfaces are in contact. Vary rarely the wheels are bent at the center only but this should work. Brad
Lo-Fi Version | Time is now: 10th June 2024 - 02:39 AM |
