Basic wiring question |
newdeal2 |
Nov 30 2004, 11:22 PM
Unregistered |
In the engine bay, what is the white wire by the dizzy for, the red/green towards the pass side tin and where does the large bundle of grounds from the center of the harness bolt to ?? I missed these in my notes.
scotty914 |
Nov 30 2004, 11:55 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
white wire is either oil pressure sender or if a 1.8 its the sender from the coil to the brain ( not to sure )
group of grounds to top center of motor should be 3 spade terminals on motor split line red green oil temp sender |
JeffBowlsby |
Dec 1 2004, 12:01 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The single white wire if its from the FI harness is for the Thermotime switch down near the tin, top passenger side of the engine.
tbox56 |
Dec 1 2004, 09:39 PM
Member Group: Members Posts: 54 Joined: 14-November 04 From: Colorado Member No.: 3,115 |
see if you can find the wire on one of these electrical digrams Pelican Parts elecrtical digrams
markb |
Dec 1 2004, 11:30 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
The white wire on my 1.7 is for the AAR.
Lo-Fi Version | Time is now: 8th June 2024 - 03:11 PM |
