Shift shaft install... |
MikeM |
Jun 23 2013, 08:51 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...while swapping transmissions I decided to replace my leaking shift shaft seal.
Well, the shaft came out of the trans and now I'm not sure of how to re-install it. Does it get held in place by the "console"? Thanks as always.... Mike |
Cap'n Krusty |
Jun 23 2013, 09:33 AM
Hi all...while swapping transmissions I decided to replace my leaking shift shaft seal. Well, the shaft came out of the trans and now I'm not sure of how to re-install it. Does it get held in place by the "console"? Thanks as always.... Mike OK. I'm guessing it's a side shift trans, because you don't give us much information to go on. Drain the trans (first making sure the fill plug will come out!), remove the console, and take a look. If the shaft came out, something's missing/broken. Sounds to me like you've sheared a roll pin. For a good blow up of the assembly, see this link: http://www.porsche.com/usa/accessoriesands...partscatalogue/ Select 914, go to transmission and then find the linkage pictures. Scroll to the appropriate picture. The Cap'n |
MikeM |
Jun 23 2013, 09:38 AM
Sorry...I was just about to add that it's a 74 side shifter.
I took the console off and the shaft came right out as well. Shifted fine last time it was in my car. The complete shaft came out with the inside 3 toothed part attached. Thanks for the link... Mike |
Lo-Fi Version | Time is now: 8th June 2024 - 02:21 AM |
