High Amp Alternator conversion, New voltage regulators necessary? |
pgollender |
Jun 23 2013, 11:42 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
What kind of problems may I encounter when replacing my 55amp alt with 75 amp alt? Would I need to replace my voltage regulator? I also want to change my fuse box from Bay Area Motor Trends. Putting in a better sound system and worried about power draw. My engine is curently out so might want to take advantage before putting in back in.
larryM |
Jun 25 2013, 01:50 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
the regulator only handles VOLTAGE - not current - it does not care what your output current is but you'd be advised to use a new style electronic regulator just for modernization fwiw - i put in the JSWest fuse panel last year - it's a nice improvement\ What kind of problems may I encounter when replacing my 55amp alt with 75 amp alt? Would I need to replace my voltage regulator? I also want to change my fuse box from Bay Area Motor Trends. Putting in a better sound system and worried about power draw. My engine is curently out so might want to take advantage before putting in back in. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:27 PM |
