Oil tank hole saws, Anyone have them |
Kerrys914 |
Dec 1 2004, 02:36 PM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
Anyone have the hole saws needed to cut the holes for a six oil tank? I figure they are something you will not use too many times.
What are the sizes of the holes and do you want to get rid of them (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/beerchug.gif) |
Root_Werks |
Dec 1 2004, 02:56 PM
Village Idiot Group: Members Posts: 8,333 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
If someone doesn't respond by the time I can. I don't recall, but I will check. There are three sizes needed. One for the oil filter, one for the oil neck and one for the breather/pressure line. When I bought mine, I just came in 1/4" or so from the raised circles. Worked great.
I just bought cheap hole saws and you know, after like 6 conversions, they still work. (IMG:style_emoticons/default/biggrin.gif) |
Joe Bob |
Dec 1 2004, 02:59 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Yup...cheapy hole saws for doors work.
Kerrys914 |
Dec 1 2004, 03:11 PM
I would have thought the door hole saws would have dulled up? I have a crappy set of hole saws and they dulled cutting my antenna hole?
Will the variable hole saw work? I have see one that is adjustable. Thanks |
Root_Werks |
Dec 1 2004, 03:22 PM
By the time I am done drilling holes, my 3/8 drill is smoking, no kidding. I use the hole saws that screw onto a drill bit individually. Honestly, they are big teetheded too. (IMG:style_emoticons/default/biggrin.gif) I think they are meant more for wood? Don't know, didn't care. They litterally throw metal shavings all over the place when I cut. Maybe I just got lucky and got a good brand? Lowe's doesn't carry them anymore. Wait, it was Eagle when I bought them. (IMG:style_emoticons/default/sad.gif)
Trekkor |
Dec 2 2004, 03:15 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I have a set of the Milwaukee hole saws. They are bi-metal and have sharp teeth like a sawzall blade.
I think I have all the sizes needed except the filter hole. for that one I will use the Dremel or a jigsaw. KT |
Eric_Shea |
Dec 2 2004, 03:33 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Plagerized...
The installation of the oil tank requires you to drill seven holes in the side of your engine compartment. Fortunately, all 914s have indentations in their sheet metal where the holes are to be drilled. If you look on the side of the wall inside your 914, they are located just above and below your relay box. The holes that must be drilled require a set of hole saws: 4" to 4.5" for the oil filter 2" for the breather hoses 2.5" for the filler neck 1.5" for the 2 hole return line holes. On early cars, there is a hole already drilled in the engine shelf of the 914 (covered with a plastic plug in most cases). |
Lo-Fi Version | Time is now: 5th June 2024 - 07:59 PM |
