Case numbers?, Can't seem to find them |
motolitho |
Jun 26 2013, 10:03 AM
Newbie Group: Members Posts: 14 Joined: 20-May 13 From: Arvada, CO Member No.: 15,896 Region Association: Rocky Mountains |
Recently purchased a 1973 2.0 but I cannot confirm the engine. I am confused by the fact that there are no numbers in front of the oil tower OR where the 1.7 numbers should be. Has the large square airbox (seems to be intact fuel injection)... can anyone explain the 3 or 4 intake bolt thing to me? How do I tell what I have?
(IMG:style_emoticons/default/dry.gif) |
stugray |
Jun 26 2013, 10:06 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
3 bolts on the intake manifolds means a 2.0L head.
4 bolts = 1.7 or 1.8. You can have 4 bolts and still have a 2.0L engine if the PO added bigger jugs. can I ask what/where you bought yours? And welcome to the front range 914-insane asylum. Stu |
motolitho |
Jun 26 2013, 10:11 AM
3 bolts on the intake manifolds means a 2.0L head. 4 bolts = 1.7 or 1.8. You can have 4 bolts and still have a 2.0L engine if the PO added bigger jugs. can I ask what/where you bought yours? And welcome to the front range 914-insane asylum. Stu Picked it up from a dude in Ft. Collins... I have a previous post with pics. Runs pretty good, pretty rough hell hole, floor pan welding. Really bad black (rattle can) paint job. Thank you, I am working on getting set up on the Yahoo forum, but I had an account years ago and can't remember password stuff. Looking forward to meeting up with you guys if you ever do. |
Cap'n Krusty |
Jun 26 2013, 10:16 AM
Recently purchased a 1973 2.0 but I cannot confirm the engine. I am confused by the fact that there are no numbers in front of the oil tower OR where the 1.7 numbers should be. Has the large square airbox (seems to be intact fuel injection)... can anyone explain the 3 or 4 intake bolt thing to me? How do I tell what I have? (IMG:style_emoticons/default/dry.gif) The 3 or 4 bolt intake manifold method of identification refers to the number of studs used to fasten the intake runners to the heads. All '72-'79 bus engines, all T4s, all 1.7s, and all 1.8s use 4 studs to secure the runners, 2.0 914s and 912Es use 3. Look below and on either side of the injectors for the nuts. Another easy thing to check is the location of the spark plugs. 2.0 914s and 912Es have the spark plugs mounted next to the intake runner mounting flanges, low on side of the tin. All other T4 engines have the access holes on the top of the tin. By "airbox", I'm guessing you mean the air filter housing. The term "air box" is used to designate the mass air flow sensor on the 1.8 914s and 1.802.0 bus and T4 VWs and 912Es. The Cap'n |
SLITS |
Jun 26 2013, 10:17 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Stu,
You forgot the 2.0L Bus engine ... it will have 4 stud heads like the 1.7/1.8 Inside the rocker box, the heads will have a number: '72 - '73 1.7 = 021 101 371J or 021 101 371Q 1.8 = 021 101 371H or 021 101 371S '76 - '78 2.0 Bus (type 2) = 022 101 372G 914 '73 - '76 = 039 101 371A *** '75 - '76 heads will have the air injection hole into the exhaust port but still carry the same part number. Hi John ... ya beat me to it! |
motolitho |
Jun 26 2013, 01:09 PM
Is it odd that there are no numbers?
SirAndy |
Jun 26 2013, 01:17 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is it odd that there are no numbers? If i remember correctly, replacement engine cases from Porsche were not stamped. (IMG:style_emoticons/default/idea.gif) |
Dave_Darling |
Jun 26 2013, 05:17 PM
I also believe that 912E engines were stamped on the fan shroud somewhere.
Haynes says that some of the 1.7 engines were stamped on a boss on the side of the motor. More were on the boss on top, right-rear quadrant (that's as mounted in a 914). Many of the VWs and the 2.0 914s were stamped in front of the oil filler. Here's a pic of the two common locations: (IMG:http://www.914world.com/bbs2/uploads_offsite/tunacan.net-121-1372288655.1.jpg) Hot-linked shamelessly from the tunacan.net/t4 website. --DD |
Cap'n Krusty |
Jun 26 2013, 06:09 PM
Just to make things even more fun, '72 bus motors had the numbers stamped on the fan shroud ........................
The Cap'n |
orthobiz |
Jun 26 2013, 06:17 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
The Porsche Certificate of Authenticity available through the Porsche Club of America will tell you the engine number. So if you ever find it you can corroborate it? (I think)
Paul |
Lo-Fi Version | Time is now: 8th June 2024 - 01:30 AM |
