FS 911 Stubs / Wheel Studs / Misc., 108mm Stubs / 100mm Stubs...... |
jaxdream |
Jun 26 2013, 03:01 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
[attachmentid=394
877][attachmentid =394881][attachme ntid=394883][atta chmentid=394889] Parts that I will not be using , went a different route. Post here that you will buy them , then send me a PM with your name and address and I will PM you my PayPal addy and pay using the " gift " pay . Time stamp in the pm will be first come first serve . Also PM with any questions and I will try my best to respond. These parts also posted on the Bird board . Jack 1. - 108mm early 911 Wheel stub 901.332.232.00 4 10mm X 1.5mm bolt 2 stud $ 125.00 shipped SOLD 2. - 108mm early 901 Trans stub 901.332.209.15 4 10mm X 1.5mm bolt 2 stud $ 125.00 shipped SOLD 3. - 100mm Sc 911 Wheel stub 923.332.232.01 ( 42Cr is the only cast number ) 6 bolt 8mm X 1.25mm - $125.00 shipped 4. - 23mm ATE master cylinder not sure of application , no numbers just 23 and ATE cast on body - $50.00 shipped Sold 5. - 914 CV gaskets only have 3 - $10.00 shipped 6. - Fiberglass flares , again decided not to use , never mounted still in the box I got them in ( 2005 ) - $175.00 shipped SOLD 7. - Precise SS Braid brake lines marked DOT Approved for EARLY 70-71 914 and 911/912 they only have the clip slot on one end not both , that's why they early - YOU decide if you can use them - New in pack not removed - $30.00 shipped Sold 8. - Standard wheel studs - see pic 44m long - 20pcs - $ 30.00 shipped Sold 9. - Longer wheel studs - see pic 65.5mm long -20pcs - $ 55.00 shipped Sold 10. - Set of locks with original key plus an aftermarket key . These are driver quality door handles and the frt trunk handle needs a repaint . They all work good with the occasional wiggle needed - but they all are keyed to that one key ( came off a '72 ) $ 100.00 shipped Sold Attached thumbnail(s) Attached image(s) |
tweet |
Jun 26 2013, 03:34 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
[attachmentid=394 877][attachmentid =394881][attachme ntid=394883][atta chmentid=394889] Parts that I will not be using , went a different route. Post here that you will buy them , then send me a PM with your name and address and I will PM you my PayPal addy and pay using the " gift " pay . Time stamp in the pm will be first come first serve . Also PM with any questions and I will try my best to respond. Jack 1. - 108mm early 911 Wheel stub 901.332.232.00 4 10mm X 1.5mm bolt 2 stud $ 125.00 shipped 2. - 108mm early 901 Trans stub 901.332.209.15 4 10mm X 1.5mm bolt 2 stud $ 125.00 shipped 3. - 100mm Sc 911 Wheel stub 923.332.232.01 ( 42Cr is the only cast number ) 6 bolt 8mm X 1.25mm - $125.00 shipped 4. - 23mm ATE master cylinder not sure of application , no numbers just 23 and ATE cast on body - $50.00 shipped 5. - 914 CV gaskets only have 3 - $10.00 shipped 6. - Fiberglass flares , again decided not to use , never mounted still in the box I got them in ( 2005 ) - $175.00 shipped 7. - Precise SS Braid brake lines marked DOT Approved for EARLY 70-71 914 and 911/912 they only have the clip slot on one end not both , that's why they early - YOU decide if you can use them - New in pack not removed - $30.00 shipped 8. - Standard wheel studs - see pic 44m long - 20pcs - $ 30.00 shipped 9. - Longer wheel studs - see pic 65.5mm long -20pcs - $ 55.00 shipped 10. - Set of locks with original key plus an aftermarket key . These are driver quality door handles and the frt trunk handle needs a repaint . They all work good with the occasional wiggle needed - but they all are keyed to that one key ( came off a '72 ) $ 100.00 shipped I'll take the brake lines |
racerbvd |
Jun 26 2013, 09:48 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Are you open to any trades for the flares??
jaxdream |
Jun 26 2013, 10:44 PM
Are you open to any trades for the flares?? Not at this time , I have most every thing to get my project going , money being the biggest obstacle (IMG:style_emoticons/default/hissyfit.gif) . Thanks for the offer , they are fairly thick and untouched. Jack |
Mr. Olympic Blue 2 You |
Jun 26 2013, 11:46 PM
Member Group: Members Posts: 134 Joined: 7-September 10 From: Puyallup, WA Member No.: 12,150 Region Association: Pacific Northwest |
2nd in line for the brake lines, really could use these,
Andrew |
Jun 27 2013, 10:46 PM
Payment for the brake lines sent..thanks again Jack!
Andrew |
Jul 1 2013, 08:42 PM
Received the lines today...everything as described and were just what I needed.
Thanks Jack! |
jaxdream |
Jul 1 2013, 10:34 PM
Great , glad that they will work for you.
Jack |
jaxdream |
Jul 7 2013, 08:09 AM
Bump.....
Jack |
jaxdream |
Jul 20 2013, 08:19 AM
TT......
Jack |
jaxdream |
Jul 29 2013, 06:40 PM
TT again...
Jack |
Lo-Fi Version | Time is now: 10th June 2024 - 03:12 AM |
