L-JET Fuel pump, 75 1.8 |
malcolm2 |
Jun 28 2013, 07:38 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I KNOW that I plumbed the under tank stuff correctly. Last resort, I'll pull the damn tank and look. Here is the deal. Car won't start. 25 months of work and it won't start. Pump runs but makes funny noises.
I put my red lead of my meter on the hot side of the pump, and the black one on the ground wire side. I pulled the pump thru the hole. I got + (positive) 11-ish volts. So that being said I have the wires on the correct terminals, or is that a good test for that? I took the fill neck off and watch as the key is turned and it sure looks like bubbles coming up thru the sock. Plumbing or wiring? |
jesiv |
Jun 28 2013, 07:51 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
I had the same problem... Make sure you don't have a kink in your fuel line. I added a little too much extra line.
malcolm2 |
Jun 28 2013, 09:11 PM
I had the same problem... Make sure you don't have a kink in your fuel line. I added a little too much extra line. I did have the hoses mixed up. OOPS. Fixed, but still no start. I read a post last night about the seat belt relay. Did the govm't have a NO START policy? I don't ever remember that. Just the buzzer. I have fuel pressure....40ish PSI. I have spark. All those wires under the passenger seat are all there, mounted to a relay block, but no relay. My wiring diagram for 75 &76 cars says nothing about a seat belt relay. What is next? |
jesiv |
Jun 28 2013, 09:28 PM
I guess the only thing I would add is that my pump was loud with the kink and silent without the kink. Good luck!!
Lo-Fi Version | Time is now: 7th June 2024 - 09:21 PM |
