Sawzall and the engine mount bar?, Can it be cut |
Kerrys914 |
Dec 2 2004, 07:33 AM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
I need to drop a 1.7 out of a really rusted '72. I don't want to get under the car since the doors are the only thing holding it together (IMG:style_emoticons/default/ohmy.gif)
I think it would be quicker and safer to just cut the bar (maybe at the bolts?) and the tranny mounts. Will a (IMG:style_emoticons/default/sawzall-smiley.gif) cut through the engine bar okay? I wish I had a plasma torch (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) Cheers |
URY914 |
Dec 2 2004, 07:44 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,914 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The late model bar is cast iron. Don't try it.
I would try grinding off the bolt heads with a mini grinder first. |
rick 918-S |
Dec 2 2004, 07:47 AM
Hey nice rack! -Celette Group: Members Posts: 20,471 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I would think it would be easier just to lay on the floor and reach 6" under the car with a ratchet and remove the nuta from the mount bolts. Plasma torches are cool but can cause fires easy.
URY914 |
Dec 2 2004, 07:56 AM
QUOTE(rick 918-S @ Dec 2 2004, 05:47 AM) I would think it would be easier just to lay on the floor and reach 6" under the car with a ratchet and remove the nuta from the mount bolts. Plasma torches are cool but can cause fires easy. I agree, just unbolt it. You'll still need to get under it to disconnect everything (shift rod, acc. and clutch cable, starter wiring etc, etc, etc) anyways. Paul |
Lo-Fi Version | Time is now: 31st May 2024 - 05:23 PM |
