BS Chairman |
Member ![]() ![]() Group: Members Posts: 98 Joined: 27-December 02 From: Southeast Michigan Member No.: 28 ![]() |
Late style gauge cluster in Concours condition.
Cant remember if trip odometer works or not $250 OBO plus shipping PM for more info Attached image(s) ![]() ![]() ![]() ![]() ![]() |
BS Chairman |
Still available, lower price
c12croft |
Member ![]() ![]() Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 ![]() |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
You will get a more favorable response if you would confirm the proper function of the trip meter........JMHO
BS Chairman |
Is there a good way to bench test the odometer/trip odo? I have several more that are in unknown condition.
Thought about hooking up a drill to an old spedo cable and running it. How fast should I turn it with the drill and which direction? Or is that a bad idea? (IMG:style_emoticons/default/confused24.gif) |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Is there a good way to bench test the odometer/trip odo? I have several more that are in unknown condition. Thought about hooking up a drill to an old spedo cable and running it. How fast should I turn it with the drill and which direction? Or is that a bad idea? (IMG:style_emoticons/default/confused24.gif) I test mine buy using an old trip odometer rest cable and putting it in the where the speedo cable goes. Run the drill in reverse. |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
And the trip odo can be checked by turn the metal piece at the end of that small cable on the speedo. Normally it would have a small knob on it. Can't tell if yours has it in the pics. These are in really nice shape, although for concours the red area next to the 'R' on the fuel gauge would be bright red. They all fade over time but can be repaired/replaced with some type of plastic material that is red and will allow light to emit through. If you chose to replace it, I believe you can pull the fuel portion of the gauge out from the rear of the housing. No need to remove the trim ring.
BS Chairman |
Will test over the weekend
Lo-Fi Version | Time is now: 17th June 2024 - 07:28 AM |
