Still having gear...problems |
oldschool |
Jul 6 2013, 09:52 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
So a few questions my car leaks a some amount of gear oil, From the speed-o area, If my gear oil is low can that be a reason why I have trouble getting it to 4th,And again if I down shift back to 3rd it go's right to 4th (IMG:style_emoticons/default/confused24.gif).
So what can I do to fix this. BTW I had a blast driving it to work today...even with the gear deal... |
oldschool |
Jul 6 2013, 10:51 PM
Anyone.... (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Maltese Falcon |
Jul 7 2013, 12:40 AM
Advanced Member Group: Members Posts: 4,700 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Jaime,
Sounds like you can do some quick and inexpensive Maint. to your shifting issue. First, drain the gear oil. Check the gear oil and drain plug for debris. Repair the o-ring on the Speedo drive. Next inspect the joints on your shift rods, from the shifter back, replace the worn parts. Replace the nylon bushing in the lower bulkhead, its probably original, dry and cracked, or missing. If your Trans oil was absent of metal debris, pump it full with some good swepco oil. If your old oil had metal debris, you are probably looking at an overhaul. Try the inexpensive route first. Marty |
etcmss |
Jul 7 2013, 01:54 AM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
has there been some linkage problems before as this sounds like a linkage setup problem first.
Mblizzard |
Jul 7 2013, 05:15 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Jamie. When I first got my car there were shift problems. The gear oils was very low. Filling it up helped but replacing the worn firewall bushing was the key. So low oil can be a part of it but replacement of worn parts is the total solution.
Dr Evil |
Jul 7 2013, 07:50 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Metal debris on the mag plug is NORMAL. Large chunks are NOT. So, do not freak if you have metal shavings..... you will.
However, you probably need an overhaul anyway if it has not been done since manufacture (IMG:style_emoticons/default/biggrin.gif) The external parts, as Matlese described, are the likely culprits. |
76-914 |
Jul 7 2013, 09:40 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Metal debris on the mag plug is NORMAL. Large chunks are NOT. So, do not freak if you have metal shavings..... you will. However, you probably need an overhaul anyway if it has not been done since manufacture (IMG:style_emoticons/default/biggrin.gif) The external parts, as Matlese described, are the likely culprits. If you don't believe it ask AAMCO. They got their little asses sued off 30+ years back just for that. They would show the metal debris to customers telling the them a major rebuild was needed. |
Lo-Fi Version | Time is now: 9th June 2024 - 11:55 AM |
